MID PTO COVER
Chad Payne
M6060 and LX3310
Nov 30, 2020
Has anyone come up with a solution for a cover for the mid pto on a LX3310? According to my dealer they Kubota doesn't provide one.
SidecarFlip
Banned
555
Why not just slip a length of tight fitting hose over it with grease in it?
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Sounds like a good idea, my neighbor was telling me I should find one for mine. I never really thought much of it.. and I haven’t looked to see how or if one would even mount some how. I think I will do the hose deal. Thanks for the idea!
Chad Payne
M6060 and LX3310
Nov 30, 2020
Yeah, I think the hose will be my best option. I was just curious if anyone had come across a specific type/size of hose that worked best.
rAzkid
BX2200D, LX3310, FEL, MMM, PF, rear mount snowblower
Nov 6, 2020
87
36
MA
I have a piece of pvc pipe with a cap on it. I cut a notch on one side that lines up with the indent on the PTO shaft (the external PTO connector pin locks over the detent). The notch is deep enough to line up with the bottom of the shaft detent and wide enough for a spring clip. Slide the spring clip, with the flat side in the slot and the round side around the pipe, over the pvc pipe so it locks the pipe over the shaft. Quick and easy on/off. I'll try to take a picture of it later, if I remember!
SidecarFlip
Banned
555
Hose is cheap and easy. What I do with my rear pto on one of my M9's. The other has the Kubota hard rubber cap. I see lots of rusty pto shafts on tractors. The surface rust makes hooking up stuff much harder. I keep my hose and cap with grease inside to grease the splines when it's on. A greasy shaft is a happy shaft... 😀
MNVikingsGuy
LX3310, FEL, 60" bucket, 60" grapple, 60" box blade, 60" flail, LX2980 blower,
Sep 7, 2020
215
148
Minnesota
There seem to be so many "things to worry about" as a new tractor owner. Is this one that really needs to be added to my list, or is this only for the most cautious owners? (I am not criticizing either perspective, just looking for relative risk guidance)
rAzkid
Nov 6, 2020
87
36
MA
A cover keeps the PTO shaft cleaner so it will be easier to connect implements to! Low cost and cuts down on connection times. The first time you get an implement PTO shaft stuck or can't get it to go on you will wonder why you didn't make a cover.
SidecarFlip
Banned
555
Exactly. Nothing better than a rusted up pto stub to make (or break) your day when you want to put something on it and it won't go on.
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
There was someone on the forum that got something just the right size and shape for a B2650, for free from his dealer, that came as packing for some other piece of equipment. Sorry I can't find that old post to be more specific.
I lost interest in the need when I realized this tractor was going to have the MMM on the mid pto in the summer, and the snowblower on the rest of the time.
Chad Payne
M6060 and LX3310
Nov 30, 2020
I was able to fabricate something today out of PVC fittings with some modifications. The coupling came with a rubber type bushing that fit over the pto nice and snug once I hollowed out the inside of the coupling a bit.
Since we don't have any implements for the mid mount (using a rear finish mower) I wanted something that would protect the mid pto from dirt, dust and debris. I think this will be perfect!
73gitane
B2320
Jul 11, 2020
Portland Oregon
Yeah when I bought my B2320 I wondered why Kubota put a cover on the rear pto but ignored the mid pto. After years of no hint of rust I lost interest in their reasoning.
Steve
RDinNHandAZ
Kubota BX1870, FEL, BX5450 Snowblower, back blade, customized snow cab
Jun 26, 2022
89
105
Lakes Region NH and Sonoran Desert AZ
