Hi there..... I’m new to the forum so pardon any terminology flukes as I am not a mechanic but somewhat mechanical.
I have owned the G2160 (D782 engine) for 12 yrs with no issues. Tractor has under 400 hrs. Just recently noticed white smoke when reving above half. At idle is fine. After reading the manual there could be fuel injector timing or clogged/ damaged injectors. The flywheel timing mark lines start with half line then full line. I’m assuming 3rd full line is wher it needs to be set at? Also, my battery is completely shot and had to jump start to turn on. Could that have to do anything with fuel system not feeding enough fuel? I plan to get new battery tomorrow. Tractor never had any issue or any smoke and coincidentally smoke and battery started somewhat at the same time.
I plan to change both fuel filters and probably get fresh diesel to rule out clogged filters or bad diesel. I change filters every year and a half and go through 2-3 full tanks a year.
Am I missing anything here?
Any help is appreciated
