Have a B 1550 4wheel drive std transmission Replaced hydraulic pump ,cleaned transmission oil strainer, and filled with fresh Kubota utd fluid After fluid was installed tractor was allowed to run without moving for 5min Tractor currently has a front mounted snow blower on it with hydraulic lift Blower lifted normally and power steering working normally 3 point hitch lift arms were stored in upright position After about 20 minutes of snow blowing a whining sound was heard from rear of tractor The same sound as you would hear when power steering is cranked all the way in one direction This sound lessened when the joystick was activated and went away completely when the blower was in float position
My 3 point hitch lifting arms are stuck in the upright position
I have tried adjusting the lowering speed control and checked the transmission vent under the seat for blockage
Everything else runs normally no more unusual noises
Any suggestions???
Any suggestions???
