chriscozi
BX23S 3rdFunction TerraKingBagger 4ftBoxBlade 5ftPlowBlade 3ptQuickHitch
Happy Turkey Day all!
Busy owner of a BX23S - almost a year now.
Using this a lot because it does way more, more easily, than my old HUGE Ford 4500 TLB (14,000 lbs).
Although the TLB did pull large stumps with relative ease.
On to the question:
According to all I read, here and the shop manual, the backhoe hydraulic lines are Power Beyond and Return.
This SHOULD mean that I can hook other 3pt attachments that have a hydraulic option,
like a splitter or a hydraulic top link which have in/out lines, directly to the in/out for the Backhoe when it is detached.
The lines currently have to be connected together when the backhoe is off of the tractor.
Please tell me if this is correct as this seems so simple no one has answered it completely to my knowledge.
And if this is WRONG please point me to an authoritative method of accomplishing the 3pt + hydraulic options.
I also understand the ~9 gpm limit of the tractor and that slow action will be normal.
A splitter with a 4" cylinder of 20" is ~1 gal. so 1/2 the gpm at ~2k rpm might yield 30-45 second cycle on the splitter at worst.
THANK YOU ! ! !
On to the question:
THANK YOU ! ! !
