Bent Tine
aaluck
Oct 9, 2019
993
842
Snowdoun, AL
No worries - I found it used at a dealership about an hour away. After some haggling, I got it for $600.
That's pretty good. Now my (stupid) question for you or anyone is this... I understand that I would need some additional hydraulics to the front. What does that entail and about how much would that be.
bluedunn
BX1860, FEL, MMM, Heavy Hitch Back Plow Blade
Aug 29, 2019
304
40
Thetford, VT
Yep, you’ll need either a third function kit or less ideally (at least on the BX) rear remotes.
Depending on the kit, you can expect to pay between $500 and $800 for the third function kit. The install is fairly straightforward and takes some basic mechanical skills and tools. I ended up with a Summit kit, which I turned out to be easy to install and their support is great. My emails were returned quickly when I had a question.
Hope this helps!
