Looking at buying a B7800
BoB F
B7800
Nov 19, 2020
14
Dunstable MA
Hi... new to this forum. Hoping to purchase a B7800 this weekend... good model? Dependable? What to look out for? It's going to be my first hydro (had a Deere 650 8spd) and I'm a bit nervous about their performance. Any thoughts on that? I'm told it's necessary to run the tractor at "at least" 2100rpm, and ideally at 2600rpm to use it... seems pretty high rpm to just "use" the tractor, but I'm coming from a history of a manual clutch system where I routinely ran the unit at 2000rpm or less to achieve anything I needed to accomplish and I worked that little tractor HARD. I'd really appreciate your experience and thoughts before I go look at this unit on Saturday. Thanks guys! BoB
3,069
Bob,
I think you find the B7800 to be a fine machine. I WOULD ask if/when fluids were changed and what was used fluid wise. Kubota's HST are almost bullet proof - HOWEVER, wrong filters, wrong fluid, wrong thoughts about those two are what caused most problems.
AS for performance, you will find you will do more work per unit of time with that HST than a geared machine when movements forward and backward are needed. The HST does have distinct DISADVANTAGE - pto HP is about 10% less depending on the model.
And as for running at "X" RPMS - Some things require more HP to do the job well. ONE thing you do not want to do is operate in a toooo low of a RPMs - lugging the engine is terrible for a diesel. Running at WOT will not hurt a bit, but sometimes it is not necessary to do so. I find on B's that 90% WOT is a nice vibration point and on my BX about 85% ...again depending on what I am doing!!!
BoB F
B7800
Nov 19, 2020
14
Dunstable MA
Bob,
Hi 85Hokie... Yes, I understand about lugging an engine, but with my Deere, 1500rpm almost never lugged down... it just did the work with a smooth even engine speed. Running at twice that rpm seems wasteful for fuel, and excessive on engine wear over time... that's a LOT of engine wear over a couple thousand hours of operation. I've also heard on another forum of issues with the Kubota hydros "bypassing" under a load while pushing, or climbing a grade with a full bucket, and the answers given were to back off the throttle and 'crawl' the several minutes it took to get to the top of the grade (not steep according to the questioner)... that doesn't sound attractive to me where with the manual trans I just scooted up ANY grade (shy of tipping over) w/o any added stress to the engine. Has this been YOUR experience with these hydros?
SDT
Apr 15, 2018
3,690
1,414
I have 5 Kubota diesels. Four are HSTs.
I do not remember ever operating any of them at WOT and rarely rated RPM.
No problems.
SDT
3,399
I have a B2910 which is the same tractor as the B7800 with deluxe features. It is 18 years old and has about 1800 hours on it. I do not think you have to worry about the B7800 being a reliable tractor.
The only time I run mine at full RPM is when I use the brush hog. Which is rare. Most of the time I run between 1500 and 1800 RPM. If I am doing loader work and want to save time, maybe 2200 RPM max. But that is rare.
I usually run M range. And we have hills here, nothing flat really. L for loader work or when using a box blade. The biggest shortcoming is the tractor is kind of light and you will lose traction before you lose power. Even with loaded tires and in 4WD.
Would I sell or trade in my B2910? Nope. I have this fleeting idea of buying a L2501, but if I would the B2910 would stay, since I have rear hydraulics on it and it would be a good partner to the heavier L2501.
Do I think the B7800 is a good tractor, most naturally. The B2910 is just a bit better because of some of the deluxe features, like extendable lower link ends for 3PH hookup, and telescoping stabilizers.
3,069
Hard to compare a diesel model vs another "similar" model -
For example - a L2501 I think has a top end at 2200 rpms according to specs ..... why? Probably to keep the HP below the magic threshold without DPF - but a BX can wind out at 3400 rpms. SO two different engines making HP at two different RPMS. SO running a deere at "X" rpms geared and a Kubota HST at "X" leaves way too many variables to have a proper decision to be made on that amount of info. As for running at twice the RPM's - that math cannot compute - again 2 entirely different engines designed by two different manufacturers. AS for fuel consumption, look at this chart of the B7800 engine,
fuel consumption for this engine is the same at 2000 rpms as it is 2800 rpms - and the hp has increased - true torque has gone down, but the engine is running at a rpm to cut or pull or whatever the engine is designed to accomplish.
As for wear on engine, you would be surprised that the LACK of wear on an engine at a rated RPM - whether or not you run your engine at X or Y rpms is completely up to you, but the engine wears the most when you turn your key - period, once it is to temp - the wear is almost none. And as for your information about "bypassing" on a hill - true it does not do well to go uphill in a HIGH range with bucket fully loaded, same thing as moving up that same hill in 4th gear from a standstill on a 4 speed tractor. What you read on the "other" forum is someone that wants their cake and icing and eat it too!!!
Newer machine HAVE to be run at their higher RPM's due to the regen's it must go through.
HST's are designed on either 2 speed or 3 speed DEPENDING on the proper use of the machine - notice I said proper .......... too many people think a BX should be able to pick up the ass end of a truck and sprint around the yard with it in tow!
Information is just that - information, some people will never listen to simple scientific fact, some will buck the system due to a myth that someone else told them.....
The myths about synthetic oils come to mind, sooooo many people BELIEVE that it causes seals to leak or the engine needs to be broken in first then switch...... Neither being true ( a seal leaks because it is bad - and the oil that the synthetic replaced had a higher viscosity than the synthetic)
the reason I bring up that point is this - Kubota along with other diesel manufacturers KNOW how the engine should be run, and they make a manual accordingly. I agree that running an engine wide the hell open for no apparent reason foolish, but it is designed to be run at that RPMS for the life of a engine!
Best point to understand is a diesel generator - there typically is no variables in engine rpm - turn it on and it runs at rated RPM to produce the power needed.
Again - the point made here, run as you see fit, as long as it works for you. And based on information - there are few kubota's I would NOT want to own. ;)
BoB F
B7800
Nov 19, 2020
14
Dunstable MA
Thank you, Hokie... all of your points are well taken and expressed. I've used it a few times since running it between 1500 and 2000 depending upon what I was doing and it works just fine... a change, yes, but something I can adjust to.
