Bx1880 Upgraded Tires
xrocketengineer
Nov 14, 2020
916
882
Merritt Island, Florida
Hi everybody from rainy and swampy Florida. I have a BX1880 that I bought new last year with a 48 in. belly mower and FEL/grapple. It came with R1 tires that worked sort of OK during our "dry season" for mowing and also for other chores like hauling out cut down trees and limbs. But the rains came in around May and they are still here. The soil gets so soft that that the front tires sink in all the low spots around the yard and create incredible ruts. Forget about using the FEL there. In the other areas, what has happened is that the tire lugs appear to put so much pressure on the soil, that not only that creates indentation as you mow but also the mower cuts lower as the tractor settles and has messed up the grass.
So, my conclusion is that the tires are too small and the R1 pattern is way to aggressive for my use. I have just bought a set of "all terrain tires" with wheels from The Mowers Parts Group for the BX2380/Bx2680. I have not tried them yet, I do not expect miracles but I hope that my lawn will improve eventually.
To not make the story drag on much longer, the bottom line is that the bigger tires will fit perfectly the BX1880 with the 48 in. deck with no modifications or adjustments needed with almost an inch of clearance to the closest point being the left rear anti scalp roller on the deck with it all the way up.
Now, these tires have a rounded shoulder unlike the R1's and R4's. I would assume that the roller would be a lot closer to the tire shoulder with those.
What I also believe is that since the frame and mechanicals are the same on the BX1880 as the BX2380/BX2680, is that the 48 inch mower would fit those models too with the possible R1/R4 tire clearance limitations on the deck roller.
I hope this helps to shed some light on the tire upgrade path for the BX1880.
armylifer
Mar 26, 2013
2,331
1,086
Thurston County, WA
I have a BX1860, which is the same size as your BX1880. I upgraded the tires on my tractor some time ago and I am very happy with the upgrade. I went with the turf tires though.
I have the 54"mower on my BX1860 though. I have about 1.5 inch clearance between the right rear tire and the roller on the mower with the mower raised all the way to the top position. The turf tires have a rounded shoulder like what you talked about and I have never had any rubbing between the mower deck and the rear tires. The only issue I experienced with the front tires is that they rubbed my 54" mower deck when making a left turn. I solved that issue by adjusting the wheel stop on that side to where the tire no longer rubs the mower deck when turning left. I have a little loss of turning radius to the left but the right tire does not rub the deck so turning right is not affected at all.
xrocketengineer
Nov 14, 2020
916
882
I read your previous post which helped me a lot to make my decision. However, what I found out was that as the tractor models progressed from the BX1860 to the BX1880, the wheel base increased from 52.8 in. to 55.1 in. The BX2360/BX2660 wheelbase is 55.1 in., the same as the all the BX23xx/BX26xx. Apparently for cost reasons when the 80 series came out, Kubota decided to use the same chassis and transmission on the lower cost BX1880 as on the other more expensive models. My transmission has a BX2380 part number sticker and the front differential gears part numbers are the same for all the bx80's per the Messick's website.
So it appears that upgrading to the larger wheels and tires is more straightforward on the newer model.
Sorry about all the verbiage, but I tend to over analyze this kind of stuff before making a decision and in the end sometimes I will screw it up anyway. :eek:
Cheers!
armylifer
Mar 26, 2013
2,331
1,086
Thurston County, WA
Cheers!
I am glad that something I wrote helped you to make your decision. I saw on this site a few years ago that someone else upgraded their BX18xx to the larger wheels and that helped me make my decision to upgrade. I am glad that I did and my only regret is that I did not do it sooner.
So we all benefit from others experiences both good and otherwise. That's what this site is all about and one of the best reasons to visit daily.
Snave
BX1880, LA344s, Back Blade
Nov 24, 2021
10
Prospect, Nova Scotia, Canada
Thanks my 1880 tires are getting a bit worn and thinking that an upgrade with perhaps increased ground clearance would be a bonus. Read some time ago that there may be a an engineering concern with the increased ground speed exceeding engineered geared ration or something beyond my intellect like that. Maybe not a concern at all. If the finance committee approves I think I will pull the trigger. Thanks for the help.
Bearcatrp
Mar 28, 2023
1,389
1,010
Minnesota
I know the tires from the 23S work great. I put R4’s on for winter duties. But from past posts I’ve read on this forum, if you go larger tires, they will rub on the 54 inch deck. I plan on putting my deck on in the spring to see if they will rub. Have read the 60 inch deck does not rub. Not sure about the 2380 or 2680 working on the 1880. If you crawl underneath and look at the plate on the rear axle, it’s stamped 23S.
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
208
161
Villa Rica, GA
This was very informative. Is there any concern about additional wear on the front and rear bearings due to the increased size and weight or turning radius issues?
Bearcatrp
Mar 28, 2023
1,389
1,010
Minnesota
Think the front and rear axles are the same across the BX line. No problem on mine, doing this for 3 years now.
js312
BX1880, LA344S, 48" MMM
Jan 28, 2024
54
32
New England
I've got the same machine with the 48" MMM and find the tires (particularly front) aren't ideal for exactly the same reasons you did. I was thinking about upsizing this spring. My factory 16" front OTRs are 6 ply and most of what I'm finding in 18" is 4 ply. Should I be concerned about that given the potential weight of the FEL and whatever's in the bucket or is upsizing already providing extra strength?
I was considering the Carlisle HD Field Trax - we've got those on John Deere x700s at work and they perform great. I'd then probably pick up some factory front wheels from a 2380 and use my existing rear wheels and just have someone take out the rim guard, mount the new tires, and refill.
SRD-BX
2022 Kubota BX1880
Dec 30, 2024
10
15
Ottawa, Ontario
I installed the larger wheels from a Bx2380 on my bx1880. Fit is perfect and no rub with 48” MMM. You can see the size difference in last pics. Also just added 2” spacers, still no issue. IMG_2454.jpeg IMG_2452.jpeg IMG_0157.jpeg IMG_0158.jpeg IMG_6193.jpeg IMG_6194.jpeg
Shawn T. W
Dec 9, 2024
836
1,511
SW Missouri Ozarks
Look at the sidewall of the tires for the weight rating ... Generally larger tires of the same ply rating have a great load carrying capacity ..
Bearcatrp
Mar 28, 2023
1,389
1,010
Minnesota
js312
Jan 28, 2024
54
32
New England
I installed the larger wheels from a Bx2380 on my bx1880. Fit is perfect and no rub with 48” MMM. You can see the size difference in last pics. Also just added 2” spacers, still no issue. View attachment 171329 View attachment 171330 View attachment 171331 View attachment 171332 View attachment 171333 View attachment 171334
Looks great! Do you notice any improvement in matting grass less while mowing? I struggle with that a bit and figure the bigger footprint will help with that.
Interestingly, it's not printed on the sidewalls of my tires.
OTR's website lists 760 lbs for the 4-ply version. The 6-ply version isn't visible, but it is in a hidden table in the HTML code and it shows the same weight rating. When comparing 2 and 4 ply versions of the same size (in other sizes that are visible in the table), the weight rating doesn't vary there either. So, apparently the official published weight rating is only part of the equation.
John Deere lists the M141464 18" Field Trax tire at 830 lbs, but it's 4 ply.
I'm could simply get Goodyear R14Ts mounted on wheels straight from Kubota and have the rear ones loaded again.
I think I could solve a few issues here - the weight versus surface area sinking the front when using the loader. A little more ballast with just loading the rears given they're larger tires on the same size wheel. Also (hopefully) slightly improve the grass matting issue given the added surface area.
js312
Jan 28, 2024
54
32
New England
It certainly floats a lot better with the extra footprint!
Good to hear! Even without the loader mine mats the grass pretty bad as-is so I need to take it slow and heavily overlap passes to lift the grass and get a nice cut. I have to get a couple filters from the dealer soon, so maybe I'll ask them what they can do on the R14Ts from the 2380.
