Fatfenders
LX2610 HSDC, LX2980 64" Commercial Snow Blower, FEL w/60" QA bucket, BB1260 Box
Since we're enjoying a little reprieve from cold weather in Northern WI, I worked on fabricating rubber scrapers for my Land Pride R1572 rear blade today. My company will be doing snow blowing this Winter with my LX2610HSDC set up with a 64" Commercial Snow Blower and the Land Pride RB1572 (72") rear blade should be the perfect compliment for that. Adding the rubber blade will prevent damaging my client's concrete or asphalt driveways.
As you may know, I am certainly not the first person to do this, but this is the process I used.
I purchased one of these at a Fleet Farm in Antigo, WI. This seems like it would be a common item at any farm supply store. This mat is listed as a 4' x 6' x 3/4" thick mat.
Fleet Farm Stall Mat <- Click
The mat is VERY heavy, so with my wife and daughter's help, I moved this mat from the back of my truck to my flatbed trailer. This job would be very difficult without a large flat surface to work on. For cutting, we positioned the mat with the piece I was cutting off, hanging off the end of the trailer. The mat was cut with a Milwaukee 7 1/4" circular saw. Cutting rubber creates a LOT of drag on the blade. A lesser quality saw may not have handled it. As it was, while I was cutting, my wife pulled to cutoff piece away from the cut to prevent the saw from stalling due to drag. This method creates a lot of rubber powder and occassionally a little smoke. I wouldn't cut it in the house...
There are no pictures of the cutting as we the three of us had to focus on the cutting. What we ended up with was 8 strips of rubber, 6"x 72" (the width of the mat). Conveniently, there were grooves about 1" apart on the back of the mat, so no measuring was needed. IF I were to do this again, I'd cut them at 11". That would provide 4 strips 11" x 72". The 11" wide strips would be reversible when one side wears out and save drilling half the holes.
I laid the steel blade edge on the rubber strips to mark for holes. I used a round soapstone a little smaller than the diameter of a pencil to trace the hole position onto the rubber. Here you can see one hole started on the right side of the rubber and the next holes marked as squares in white. Tried a Sharpie and couldn't see it.
Drilling the holes was quite a challenge, until I figured out how to do it without leaving a rubber plug in the hole saw. A 3/4" (19mm) hole saw was used to make the holes for the 5/8" x 2 1/2" Grade 5 bolts.
When drilling the holes, drill about 3/4 of the way through. Using a small screwdriver poke through the center of the whole created by the hole saw. Then flip the rubber strip over and drill slowly from the back side using the pilot bit in the hole created by the screwdriver. You'll then be able to easily pull the rubber plug out of the end of the hole saw. CAUTION - the hole saw will be HOT!
And this is the finished product. The blade is now assembled and ready to use. The bolts should have washers which I'll add soon. The bolts are held with a lock washer and nut. I'll likely replace the nut and lock washer with a nylock nut.
There is a little over 1" of rubber past the edge. I will be interested in seeing how this works with the blade facing forward or back and how long it lasts. With 7 extras, I should have a good supply of blades for a few Winters anyway.
