Smokeless
						3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
			Guess I miscued, yes HST 3901. Ok, Super UDT it is, thanksI would bet S-UDT2..... and I would use nothing but... IMHO
Now having said that...........I am gonna AssUme that it is an HST?????
If stick, I would not guess - even though S-UDT2 there too.
It is $$$ stuff - but it did make a huge "whiny" difference when I replaced my hydraulic oil in my BX.....Guess I miscued, yes HST 3901. Ok, Super UDT it is, thanks
Possible Thread Highjack:
Is there a problem with keeping a partially empty 5-gallon jug of S-UDT around, given temperature swings of +90 to -20? I just got my 2012 HST, and don't need any fluid but want some on hand for when it does. I'm not anticipating a fluid change $oon, so will probably just be topping off as implements/loader are disconnected and reconnected. (I haven't found any actual leaks yet, but it's only been 26 hours).
Buy a gallon, or buy the big jug which it may be years before I use?
I was going to suggest keeping it inside, but wasn't sure that was an option. If you have a smaller empty jug, you could pour it into that and keep it inside. But, I have 2 year old (Shell) hydraulic fluid with about a gallon left in it and it looks like new. It rarely reaches freezing temps here with short periods in the teens. As long as the bucket has the cap on it, I really don't see a problem with an appreciable amount of moisture getting in. Any small amounts of moisture will be vaporized in the tractor when the fluid gets hot running it anyway. Storing it off the ground would possibly help minimize moisture.Yeah, I was mainly wondering about condensation with air in the jug and temp swings. I can keep it in the house, I guess. Then it would actually pour if I had to add some on a below 0 day.
Thanks,
Don't keep hydraulic fluid in the house.Yeah, I was mainly wondering about condensation with air in the jug and temp swings. I can keep it in the house, I guess. Then it would actually pour if I had to add some on a below 0 day.
I did my 50 hour service yesterday and replaced my hydraulic oil with UDT2. I did this for two reasons. The first was that it had mostly UDT in it as I had a fitting spin loose and the dealer gave me a 5 gallon bucket of UDT. So, I knew it had mostly UDT in it already. Several here say they come with UDT2, I mentioned that to the salesman and he said it has UDT in it. I didn't argue. But, are these tractors being filled by the dealer when they are uncrated? If so, I bet many use cheaper UDT than UDT2 and owners are running tractors assuming it is UDT2. So, I just drained mine when I changed filters and added UDT2 so I know for sure.
Google says the best storage temperature is between 32 and 77F. I would just keep a smaller jug handy rather than a 5 gallon bucket of it. The only time you would need 5 gallons is if you had a malfunction of some kind dumping all your oil. If I had a partial bucket though, I would just hold onto it. I would be worried more about water getting in it over time more than anything.
I'm not a big believer in oil going bad over a reasonable time frame. If that was the case
Heard the whine business before. Well i guess i will try the expensive stuff and hopefully all will be better.It is $$$ stuff - but it did make a huge "whiny" difference when I replaced my hydraulic oil in my BX.....
Gonna show my ignorance here, am guessing drain hst transmission at each drain plug, then remove filters......reverse operation. Make sense????
I don't know if an "L" follows a little BX, but I've changed mine at 50, and twice since then, and I'm at 400.Makes perfect sense - I think despite the cost, you will be pleased with the new oil and the lack of sounds.
Well i will give it a shot and see where it takes me. There is a part of me that realizes the whine is an engineering decision rather than a lubrication fix.......recognizing we must have good lubricants. Thanks to all for posting, I am better informedAs to the whine, I just used the tractor for the first time since draining and filling with UDT2. My observance, the tractor did not whine like it use to. The first few minutes was actually very "quiet". However, after the tractor heated up, I notice the whine a bit more. I think it is still a bit quieter than it was with the old fluid. So, I think there is some truth to people claiming the whine is less with UDT2.
I will also add that since my tractor whined like that the whole time before the change, it probably had UDT in it and not UDT2.
I am not sure I follow this. I keep my pail of S-UD2 in the basement of my house where the temperature never changes much. What is the risk here?Don't keep hydraulic fluid in the house.
My apologies. I should have been more explicit. There is no risk.I am not sure I follow this. I keep my pail of S-UD2 in the basement of my house where the temperature never changes much. What is the risk here?
I breezed past this somehow, will have to check my manual,. Dont recall it specifying Super UDT-2, ThanksChecking my manual, (L3301 / L3901) it specifies Kubota Super UDT-2.
Manual 2wd - 28L / 7.4gal
Manual 4wd - 28.5L / 7.5gal
HST - 23.5L / 6.2gal
