Hello, all - just found this forum while looking for info on my problem, hoping someone can help!
The problem is: my L3301 (HST) won't crank. Power goes on but when I turn the key to start, nothing happens. No clicks, nothing. It stopped suddenly when I got off.
I had the problem before and had it repaired. They cleaned a switch, I don't remember which one, and things started working again. But at this point I would really rather fix it myself than have to pay for the hauling and repair again - pretty sure it's fairly simple, if I can diagnose the problem.
I'm pretty sure it's related to the PTO safety, given how it stopped. Just to get things working, I've currently bypassed the PTO switch by connecting the leads directly. Still nothing happening. I've tried doing the same with the under-seat switch in various combinations (it has 3 wires and don't see any voltage to any of them when cranking, so not sure which ones the switch connects). No luck with any of this. I suspect there's another part of this system that I don't know about.
My thinking is that if I can determine what part is bad, I can get a replacement, but so far I can't figure out what's failing. Any ideas?
Thanks in advance,
Thanks in advance,
