Front end loader 1301 And 1301S
DTW
M8200 Utility special
Aug 23, 2020
9
Western Newfoundland
I have bought a2000 (year) M8200 utility special with only 525 hrs on the tractor.
I have an 84 inch Norman single auger blower and a rear scraper blade,with the tractor.
Reading on line, the M8200 can take a LA1251 Fronr end loader or a LA1301.
I am not able to find any LA1251 or La1301 Front end loaders ,Byt I have found plenty of LA1301S Front end loader.
On the specs sheet there is some differences between the two,La1252, and La1301S.
I cannot find any specs dor a LA1301.
Ia it possible the La1301 and the 1301s are the same just missing a letter ???
I would like to know if anybody knows the difference between the 1301, and the 1301S.
And would the 1301S fit on a M8200.
All the info I find out would be much appreciated.
All the best
DTW
DrewAg
Kubota LA1251
Jun 22, 2026
AR
All the best
DTW
Did you ever find anything out regarding this?
Wanting to change the bucket, and possibly the lift arms out on a LA1252 from a LA1301S,
Firefight100
MX5200
Apr 3, 2021
115
85
63379 troy mo
here's what I found on them....." The primary difference between the Kubota LA1301 and LA1301S (often referred to casually as the "S loader") is the bucket mounting system. The "S" designation stands for a skid-steer quick-attach (SSQA) style system, whereas the base model typically uses Kubota’s older "pin-on" or semi-quick attach bucket. [1, 2, 3, 4] "
