Small Kubota tractor
KyleS
3 cylinder Kubota
Oct 31, 2020
9
Rockmart Georgia
My Kubota will start and run perfect but will not throttle up!
I’ve done the following,
New injectors, new head gasket, new pump, new fuel filter, new rings, new diesel, and it still we not throttle up. What else could it be?
Thank you in advance!
bx tractorjoe
Jun 3, 2020
258
140
loxahatchee flordia
What kind of kubota ? Possible the pin for the throttle lever inside the injection pump has come lose, or the rack arm is broke..
Is it a hand throttle or does it have a solenoid or something else?
5,447
Kyle - -
You need to give model information for anyone to give you a best guess to fix it.
"Small Kubota Tractor" doesn't work...
armylifer
Mar 26, 2013
2,061
787
Thurston County, WA
As mentioned above, we need the model of your tractor to help you. If you do not know the model maybe we can help if you post a picture of the tractor from a side view and at least one of the engine compartment. Try to show a view of the throttle linkage.
2,582
and you own a 3 cylinder ..... please do as others said. Give us model # and you will be surprised the help you will get!!;)
3,603
2,085
From your repair list we should be asking you how to fix things!
Start with the basics. If you manually move the linkage by hand does it throttle up? If not, is your fuel filter full of diesel or do you see air?
2,582
So now we are dealing with a D950-A-T
So - give us a background as to why you replaced this " New injectors, new head gasket, new pump........."
Did this over heat? Did this have low compression?
And you say it will not throttle up - so, it will start and will idle?
Give us the full history of this machine.
KyleS
3 cylinder Kubota
Oct 31, 2020
9
Rockmart Georgia
It was running perfect and just lost power, yes it starts and idles, did not over heat, it didn’t have compression that when I replaced the rings.
armylifer
Mar 26, 2013
2,061
787
Thurston County, WA
It sounds to me like you may have a broken throttle cable. Can you manipulate the throttle in the engine compartment and get it to rev up? Also, does that model have two fuel filters like the BX models do? You might want to check on that.
KyleS
3 cylinder Kubota
Oct 31, 2020
9
Rockmart Georgia
It will throttle up in the engine department but will only do so gradually, it want do it quickly
KyleS
3 cylinder Kubota
Oct 31, 2020
9
Rockmart Georgia
