Hi.. Thanks for reply.. Fuel filters very recent.. Rpm flat out.. Incline around15 to 20 degrees and yeah always been like this.. Just find it a bit painfully underpowered.. great little machine though.. Apart from that... Just wonderd if normal.. Thanks
I have a similar problem with my BX25D .... I have a good hill that I have to come up from the bottom of my property - probably in the 20 degree range ..... I cannot make it High range - get about half way up and it will simply bog down. Low range it will climb a mountain side.
My conclusion with my machine is - nothing is wrong with it!!! It has two ranges for reason, and many say well just back off the HST pedal and it will do it, nope it will not!!!
The tractor is carrying a FEL up front, and a heavy hoe on the rear - and all other things too - including my heavy butt!!!
The weight on the rear is fantastic when it comes to grip on the ground - but is hard to pull up a hill!
Your machine and mine are about the same in weight when you add up all the implements. And both have the same size engine.
I take it - 1st gear pulls it fine?
