Hey Guys new to this forum. I own a performance shop and I build turbo kits. I started in the diesel world with a 4bt swapped 47 Chevy currently making 600whp 950 tq on 70 psi. I also build custom turbo kits for bmw platforms. I purchased 5 acres of property and jumped on buying an l2501 HST. Reason being is I knew this engine was de tuned from all my research and not having a dpf was a big plus. I am also a huge fan of mechanically controlled Diesel engines. I started off doing a basic rpm increase to 2600rpms. It helped with running my PTO chipper but I eventually found out I needed more fuel. I made a very slight fuel adjustment and it did increase the power. Only issue was of course slightly more smoke. After reading about the D1703 I figured out Kubota retarded the timing to 5 degrees btdc for emissions and to help it get under 25hp and also the air box they are using is a major restriction. The 1703 can run up to 14 degrees btdc. I bumped the timing up to 9 btdc and installed a higher flowing air box and all I can say is wow this thing pulls up my driveway which is a 15% grade like no problem in mid range gear at 2300rpms. Before it would bog down below 1800. I am guessing it’s in the mid 30hp range. Just wanted to share this info. And I will be also installing an oem rhf3 Kubota turbocharger. I’ll be running low boost probably around 5-7 psi. Since I am at 3,000 feet elevation it will help a ton. I’ll post pictures and progress hoping for a solid 40hp out of this tractor
