Grass clippings and dust getting in behind dash
fmgsr
54
PA
Today I noticed, Grass clippings and dust getting in behind screen at the bottom
of the dash. The screen doesn’t seal properly. Any ideas. Vacuum it off, hose it off?
How to seal it better. BX 2380
dlsmith
BX2230, LA211
Nov 15, 2018
1,305
922
Goshen, IN
That's very common. Just vacuum it off whenever a reasonable amount accumulates.
The screen only catches coarse material, the finer stuff will get to the radiator and needs to be cleaned off to prevent overheating.
This is what I found on my BX after a few weeks of mowing this spring.
MFFI422
BX2380 -Drive Over Mower Deck- LP Tiller - FEL - LP Box Blade - LP QH - Canopy
Jun 10, 2020
81
35
Arkansas
Fmgsr. I blow mine out after every mowing. Take the screen off and the screen in front of the radiator.
7,089
I think the original post is a question about dust behind the dash of his tractor. I don't know the answer to his question, but I don't think it's in reference to a radiator plugging up.
SDT
multiple and various
Apr 15, 2018
3,335
1,117
SE, IN
Do not hose it off with water.
I have an 80 gallon 7 1/2 HP air compressor that is used mostly to blow dust and debris from my equipment. I blow off everything after each use.
Without a decent sized compressor, you can use a shop vac or a leaf blower as previously suggested.
SDT
3,944
2,605
Yikes, no screen in front of the rad on the BX's?
5,860
On my BX23s, the screen is the wrap around panel under the dash hiding the battery.. Kinda attaches with 2 clips and 2 knobs. Somewhat flimsy so if I was cutting grass, I'd add 'foam' to better seal the lips....
Boatman
Kubota L2800, Kubota BX1870
Nov 26, 2016
168
54
Mill Spring, NC, US
My BX has the open screen below the dash and then another screen you slide out from in front of the radiator under the hood.
