Front loader Adjustment for M7060 with la1154A/Ea
BigG
Sep 14, 2018
1,953
774
West Central,FL
What kind of adjustment are you looking for? Is it not working? Does the 3 point hitch work correctly? Have you checked your fluids? New filters? Type of hydraulic fluid?
5,257
1,051
Trying to adjust the Front loader so it will raise how do you adjust it found where its at but dont know how to really adjust it
The joystick has a lock on it to prevent accidental movement.
Look for a metal tab sticking out towards the front or side of the joystick.
These are two examples of locks from a M7040
Do NOT go making other adjustments as you will make a small problem very large
Raymond Arringto
M7060
Oct 14, 2020
Yes sir everything works as far as hydraulic fluid and all its just not going up you move everything else but up.
i7win7
Feb 21, 2020
3,377
3,991
Central, IL
Hydraulic coupler may not be fully seated, turn tractor off, move joystick to all positions, unplug coupler(s), reseat them and retest.
