Ventilation for a Shipping Container
Arkansasdawg
MX5400, grapple, Bad Boy Rotary Mower
Oct 7, 2020
40
I have searched the Forums but was unable to find the thread where I am certain this has been discussed:
I live in Central Arkansas, in the process of purchasing 50 acres of land and a new Kubota tractor. I have made arrangements to get a 40' High Cube Storage Container delivered to the site for Tractor Storage. Are there any concerns over storing a Tractor and Diesel Cans inside the container? It gets pretty hot in Arkansas in the Summer. Thank you
3,092
Will you have power to this container? IF so - cut a small hole in one end and another hole opposite side/end. Get a good size fan and have it turn on with a thermostat like an attic fan.
It really depends on the CFM 's of the fan - if 120 volt power - a couple of bathroom vents fans would work well enough. I have one of those "quiet" fans that when on will pull blow a lighter out as the air is sucked from under the door! OF course my bathroom is about 12' long and maybe 6' wide...... you are dealing with 40x8x8 more or less!
The trick here is that there MUST be air coming in at some point to be able to exit. I am not sure they are "water" tight - but I bet there is little air coming into it without a vent of some sort with the doors shut.
IF no power - get a solar panel / 12 volt battery and a couple of fans that will run off a 12 volt system and place vents where you wish and allow the fans to come on when you wish - plus you will always have a back up battery to jump from if need be!
more info :
https://www.gatewaycontainersales.com.au/shipping-container-ventilation-diy-guide/
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
108
sheridan
Welcome dawg,
I live down Sheridan way and would like more info on storage units. Mind saying where you found your container?
retired farmer
May 25, 2020
188
108
sheridan
I have not purchased it yet but am looking at Scottysstorage.com
Thank you dawg,
My son lives down close to Huston and can get those relatively cheap. I haven't found them to be affordable in my location, delivered that is. I may end up getting one of those carport thingies.
Arkansasdawg
Oct 7, 2020
40
Let me clarify my original question. I guess what I am asking is this. "Is it necessary to install some sort of ventilation in a shipping container?" I suspect that some folks store their equipment in these containers without adding additional vents. Anyone having issues with those?
hope to float
L3450
Feb 18, 2018
490
61
Ireland
Yes. They must be vented. They use them at a golf club I know and the machinery just rots in them without ventilation. But then again, machinery around here gets put away wet quite a lot
3,588
My 20ft container has 8 factory vents, it is in the Arizona high country, and I keep the tractor, fuel cans, oils, spare parts & implements in there with absolutely no problems. IMG_0009.JPG IMG_0020 4.11.41 PM.JPG
5,515
2,231
I live in the same general area
used to keep my race car stored in a connex when I wasn't using it.
it would get upward of 170 degrees inside at times when we had the big heat wave in '2010. I bought an enclosed and keep it elsewhere now, ventilated of course
humidity is another concern. When it cools down at night the inside of the connex that I was using would sweat. It is nothing more than an tin can.
But the one I used was not vented very well if at all (I don't remember). It was pretty tight, and didn't leak a drop was an old reefer container
thought about having one delivered to some property for a cabin, and havent' ruled that out yet. Same problem, not insulated but I reckon I can do something with that. I know someone who has two of them set side by side for a nice cabin, spray foamed, knotty pine all inside--it's NICE.
Yooper
3901 LA525
May 31, 2015
1,752
930
NE Wisconsin
I’ve got one like Bill has and it works well for storing my tractor. But I have it parked on the north side of my shop to shade it during the summer heat. They do get hot when the sun beats down on them. Do you have some trees on your property maybe you could park it under?
Arkansasdawg
Oct 7, 2020
40
Thanks for all of the replies. My container will be in the edge of the woods so not in blazing sun, I hope that helps. I like the idea of the small vents but just wonder if that is really enough to significantly ventilate the box. The whirlybird vents seems to be better but look like a pain to install. Oh well, I have a few months before the heat gets here. Thanks
Tughill Tom
B3200
Dec 23, 2013
1,492
2,193
Turin, NY
I'm on my third one and have never had a condensation issue or heat issue. I keep a Snowmobile and dirt bike in one in the from spring to fall and in the winter lawn mower. The other one has all the Kubota implements in it.
They all have vents installed in them when built, it can get on the warm side out in the ocean.
G.rid
L48 tlb, ssqa forks, manual thumb for hoe
Aug 19, 2016
207
17
Oxford, NS, Canada
It all depends what you're planning on storing in it. The attached video made me think twice about keeping anything gas related in ours.
4,267
Without vents.... they are quite the “bomb” when they go.
Attic vents and or turbo-vents work well with no power at all.
Gasoline (and propane) vapors “sink” ... so an upper and a lower vent at opposite ends are probably advisable.
Unfortunate Bystander
L-235
Oct 15, 2020
10
Santa Cruz County, CA
If you need to put the container on blocks due to uneven ground be aware that the floors are often wood and can burn in a fire scenario where the leaves and other debris on the ground are burning. I lost about two feet of floor and everything in the container smells of smoke.
