The dust cover seems to be really rotten , its just coming out in Pieces and Its almost as its glued in. ( metal ring was still in, my bad, I need to read better)The parts diagram shows the seal( gasket) being inserted from the plate cover side . But the needle bearing needs to come out to do that? At least that’s the way it appears??? Thanks for you helpThe needle bearing shouldn't need to come out. On every one I've seen, the oil seal (gasket ) is soft and gets rolled into the gland.
Like this ... tool is not needed ...
Dust leak should have a metal outer that has to be pried out like any other press fit seal. You'll be fine just note the way the original seals are in there.
Dave should have the WSM pages for you.
