Had tractor serviced, dip stick shows about an inch above the full mark..? Is this critical, should I drain and refill?
Even if the wrong filter was installed the person doing the work should have verified by checking level on dipstick. Very poor service.
Thanks for your advice...will probably go ahead and do a full oil and filter change which I normally would have done, but decided to let them do it....last time.First verify these guys put the correct filter on it!
The wrong filter will screw on (from another BX series) but the oil level will often show overfilled when it happens. I agree with the above as well, set the level correctly.
I learned this when putting the wrong filter on my dads BX1800. Could not figure out why the specified oil quantity was coming up an inch high the dipstick. Realized the wrong filter was on. Replaced with correct filter, quantity was correct.
Plan to drain and get a new filter and refill myself. It does not hold a full gallon, but that is what they charged me for.The dealer overfilled mine too on the first service. Put a full gallon in my BX instead of what was spec.
I drained out the excess. If you leave the dip stick it, the oil will not coming pouring out quickly when you remove the drain plug and it is a relative painless endeavor.
