Advice on lx3310
Mukat
Lx3310
Sep 7, 2020
I’m pricing out a LX3310 with the cab.
Im looking for advice on the option of the swift-tach loader. The option is the way to get the manifold with flat faced couplers And is supposed to let you disconnect loader from seat. I understand it won’t be as simple as staying In The seat with the cab, but thoughts on the value of this option? I think it’s about $700.
I’ve read forums to know that the flat faced elicits often a strong response one way or another.
I’ve have had pioneer couplings before and have had issues connecting them before so was leaning to the manifold with the lever as a mechanical advantage
thoughts?
MOOTS
MX6000
Jun 27, 2019
1,928
2,212
Canton, Georgia
Reading on here, the BX had issues leaking at the manifold. Maybe it has been fixed, I don’t know.
johnkn
27
Laplata, MD
I have a new LX3310 and initially thought I wanted the Quick-Tach, but after seeing it on a LX I ran away from it. The hoses are routed way outside the loader and stick what seems like 3 feet up in the air. Good luck
Mukat
Lx3310
Sep 7, 2020
Can you show a photo of how the hoses are routed on yours? Do they more follow the arms of the loader? Most every photo I’ve seen has the manifold on it.
johnkn
27
Laplata, MD
I did not get that option, I initially thought I wanted it, but after seeing it, no thanks.
Click to enlarge the bottom (2) pics.... Also, how often are you going to be removing your FEL? And how long does it take to disconnect 4 couplers? 15 seconds? Top pic is my tractor with standard couplers. Bottom 2 pics are from the Kubota site. No way I wanted all that stuff hung off the side of my tractor exposed.....
Mukat
Lx3310
Sep 7, 2020
Thanks a lot—that is very helpful.
I think I’m going to pass on that option as well. I’m not thinking I would take it off Enough to think it’s worth it
Raymo853
LX2610SU
Jun 26, 2019
71
23
Dorset, VA
I think having a cab also negates the ability to use the swift tech as designed
SDT
multiple and various
Apr 15, 2018
3,256
1,042
SE, IN
thoughts?
I was told that the single lever hydraulic manifold is available with or without the Quick Tach FEL.
SDT
