Another question about New BX23S .. Broken bolt on Backhoe
cal1
BX23s
Jul 9, 2011
34
Battle Ground, WA
I only have 14 hrs on the tractor so it's going to be hard to claim faulty maintenance. I'll at least ask to see it and take pics.
PaulR
Aug 3, 2020
581
462
Hadley, MA
:oops::oops:
Subscribed.
Brand new BX 23 S owner here, 1.2 hours of FEL time, haven't even taken the travel pins out of the hoe yet.
My dealer did in fact grease all the zerks from what I can see just by looking at it last night.
I'm going to take a closer look at the OP's pics and see exactly where these pins are and make sure they are greased.
I already saw your "paint ring" issue and had the dealer prep guy cut off a few when I was picking it up yesterday!
Paul
PaulR
Aug 3, 2020
581
462
Hadley, MA
OP: based on your pic, I'd say they definitely missed greasing that painted over zerk.
Here is a pic of my hoe, unused, just brought home from dealership. The got all the zerks for sure.
SidecarFlip
Banned
563
Seems odd to me that with a new unit the owner (you) didn't go over it and insure everything was proper before using it the first time. That is referred to as a pre operation inspection. I bet you never checked the fluid levels either or the tire pressure.
Always bad to assume that someone else did it. Assuming will always end badly.
cuzmarc
BX23S
Aug 29, 2020
Minnesota
Always one in the bunch...
5,506
2,219
14 hours.
That means that they'll try to make you prove that it was greased at 10 hours, per the books. Not trying to jerk your chain or anything, just preparing you for what could come up. They might want documentation. They're getting that way, but so is everybody else. Deere is asking for fluid analyses on engine and transmission repairs and I would assume that kubota will be doing it sooner or later too.
SidecarFlip
Banned
563
14 hours.
I bet they will and soon.
FYI, with Deere, if you have an internal failure (motor or drive line) and the fluid analysis shows a non Deere approved fluid being used, they will not honor any warranty claim. No exceptions either. You buy a Deere, you are married to Deere no matter what and not just fluids either. Filters as well. No Wix or Baldwin on a Deere unless you want to void the warranty.
SOP for me is checking fluid levels every time I use either tractor and my loaders get greased at least weekly, sometimes more if loading round bales. No backhoe here, don't want one.
SidecarFlip
Banned
563
Not really, when you own 2 units that were over 50 grand new each, you take care of them and because mine aren't 'hobby' units, when I need them they need to be ready to go, with no issues.
If you don't maintain them and they break, you come on here and ask what the heck happened.
My favorite 'chuckle' posts are the battery threads. I change out my starting batteries every 5 years no matter what and I keep the connections clean and corrosion free too.
leveraddict
Apr 1, 2019
905
594
NEPA
Paul that zerk on the right looks painted over! Although there is grease on the zerk I would make sure its coming out of the pin on the other side!
PaulR
Aug 3, 2020
581
462
Hadley, MA
you're absolutely right. I'm a newB. They painted the zerk and the whole pin. My dealership tried to squeeze grease in there and it didn't go. It's plain to see now. I made the same mention in my new owner thread.
cal1
BX23s
Jul 9, 2011
34
Battle Ground, WA
When you get your new machine with every zerk fitting filled with grease overflow, you don't typically think I'll clean that grease off and see if its paint plugged. Most of my fittings worked fine with grease flowing correctly. But it's obvious I should have been paying much more attention to the exit flow. After all it's not what goes in but what comes out that tells you if it's properly greased. My bad, I know better now.
leveraddict
Apr 1, 2019
905
594
NEPA
I was at my dealer today getting everything for my 400 hr service! Not many machines on the lot like in spring! There was only one BX23S so I went over to look at it. Same painted over zerks with grease on them, but nothing coming out of the joints! I wonder if Kubota has addresed this issue?
PaulR
Aug 3, 2020
581
462
Hadley, MA
I emailed my dealer with what I found, and a pic, and mentioned there are many of us here talking about it. He simply said "grease it". Then he went on about something I think about a design change and that they meant to paint that zerk in question, for some reason I don't know, didn't make make much sense but whatever. I tried my hoe for the first time the other night for just a few scoops after friends with beers stopped by. Seemed fine, no creaky car door sound.
haveissues
LX2610
Sep 13, 2013
26
24
northeast
Nonsense. Whoever is prepping these before paint just doesn't feel like covering up all the zerks and the dealers are not checking when they grease up the pins. My new LX had a few zerks painted over, all on the backhoe.
cal1
BX23s
Jul 9, 2011
34
Battle Ground, WA
Ok I finally got my tractor fixed. Took it back to Kubota and the tech proceeded to preplace the old pivot pin. He said it was way too hard to pound out and suppected there was something really wrong. After a lot of pounding the old pin was out. Putting the new pin was so hard that he stopped and said it looked like far side of the hole from the zerk is somehow pinching the pin. Said he'd have to grind/hone out the hole (probably a bushing inside?) to get the new one in. Took a ton of grinding and honing but the new pin finally was able to be pounded in. Grease finally came out of both sides of the joint and no noise! Couldn't really see what he was grinding but it worked. There was nothing wrong with the old pin. I've attached a pic of the shiny new pin and the old one the left side of the old pin(the greasy side) was the far side of the pin away from the zerk. This is the side that was being pinched. Still not sure how the grease being pushed out of that small hole would travel to the both sides of the A arm. But it works now! No amount of greasing would have fixed this. Before I noticed that the keeper bolt on the end of the pivot pin would quickly bind up and sear off after a while. All of my other bolts were always loose. After the operation it's now loose.
B520EA02-5FD7-47D4-A837-1E94D86D1291_1_201_a.jpeg A23A202B-2857-42F8-BAAE-9EEB8F972061_1_201_a.jpeg
6,239
While I'm glad you've got it fixed...
this concerns me..
re: Took a ton of grinding and honing but the new pin finally was able to be pounded in.
POUNDED IN ??? That should be a HUGE red flag...... there is NO way the pin should have been POUNDED in. They're designed to be silky smooth slid in, maybe a rap,rap with a very small ballpeen hammer not POUNDED in.
just be sure to add grease every 10hrs of use, just 1-2 squirts, enough to push out the old and in with the new...
SidecarFlip
Banned
563
this concerns me..
That sounds fishy to me too. The pivot pins should slide in easily. That is why they are cross drilled and a retaining bolt installed.
cal1
BX23s
Jul 9, 2011
34
Battle Ground, WA
Yeah didn't really like the solution. Tech never said anything about sliding in easily. There are bushings inside and I've never done this type of repair. All bushing work on cars are super hard to get in.
Anyway it's done and I'll be monitoring it for the rest of my ownership.
Hey where did you find the "grease every 10 hrs" reference. I've gone over the owners manual and can't find any lube interval reference anywhere. Makes sense though.
I think a more serious aspect is that there is clearly something wrong coming from the factory. Paint covered zerks is bad enough but I think there is clearly a manufacturing defect. Anyone ever heard of a Kubota recall for anything or is it a squeaky wheel situation?
3,371
I think I would try removing the pin. If it does not slip out easily, you have a problem in the making, which may not appear until after the tractor is out of warranty.
Sounds like a half a$$ed fix and not the correct solution. As said above, if things are aligned properly, pins slide in and out very easily.
Hand grinding is NOT precision machining...
bird dogger
Vendor Member
Feb 24, 2019
1,778
1,756
North Dakota
They make long pilot adjustable hand reamers just for applications like this.
