Leaky steering arm seal please help
modeladay
Sold B7100 and purchased a B2150 with FEL
Mar 25, 2016
117
10
Lincolnton, GA
Anyway it's a B2150. The seal on the steering arm is leaking is this a hard fix? it is power steering.Do I simply remove the steering arm and replace the seal or do you have to dig in to it deeper?
I have chased a lot of seals on thing yes its old, I was wondering how difficult this one was going to be? After downloading a PDF of the repair manual it looks like the Sector shaft can be removed without pulling the steering column assembly??? Photos are really bad in the PDF that I paid to download šŸ˜ž 7404A241-E4B5-4BC5-8470-A4F4FC0F678B.jpeg
BigG
Sep 14, 2018
1,953
774
West Central,FL
What do you need help with? Get a work shop manual(wsm) and ask your question. Can not help you with such a vague question.
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
Thanks, the reason why its vague is because after I loaded the photos it won't give me a field to post the rest of the message????? Anyway it's a B2150. The seal on the steering arm is leaking is this a hard fix? it is power steering.Do I simply remove the steering arm and replace the seal or do you have to dig in to it deeper?
BTW I figured out how to post this in the original post
thanks again
Dusty
5,255
1,057
thanks again
Dusty
I answered a similar question from another B series owner.
The outer seal is only keeping water and dirt out of the box not the fluid in.
Gasket #40 which is not a simple thing as the word gasket would suggest and costing $20 is the part to replace.
I suggested to the previous owner to try and just remove the sector shaft. He reported back that there was not room and he removed the complete box.
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
Thanks Dave, I have checked on all the parts I need. I had hoped I wouldn’t have to remove the boxšŸ˜ž
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
The part number 040 gasket has been discontinued??? I guess this is now a Throw away tractor. Why would Kubota quit making parts? There might be some laying around somewhere but I can’t believe this. One service guy tried to convince me that Kubota always over engineer stuff and the part is probably not needed. He said just replace the outside seal and your good to gošŸ¤”
11,042
How do you know it's discontinued, I'm not seeing that?
Calling it a throw away tractor is a little harsh.
It's a 32 to 25 year old tractor, there is no money or call for a lot of older tractor parts so they fall out of stock and no longer in production.
You will need to think outside the box if it truly is out of production, there is always a substitute to be had.
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
I've called three Kubota dealers , all have said its been discontinued and is no longer in stock as far as they could tell. Messick's have told they can get one if one of the four dealers in the country who say they have them actually do. I don't know where to start for a substitute? THANKS
Pau7220
Aug 1, 2017
785
280
Scranton, PA
Jones Farm Supply has 2 on the shelf... took about a minute to find. The other big 2 (Messicks and Coleman) say 5-10 & 3-5 days out.
As far as this comment, this seal ("gasket") is a glorified hydraulic cylinder rod seal which goes inside the gland. I'm sure it could be matched up at a good hydraulic shop.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
He is dead wrong... find a new service guy!
The other repair thread....
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
I did not take what he said seriously, service guys for the most part are appointment takers and that’s the extent of the mechanical knowledge 😁 I have already replaced a seal in the steering column so I have had the tractor apart that far. Lots of stuff so it couldn’t be that much more to get the box off( I hope!) The thing I don’t understand is marking stuff to get it reassembled correctly. Will I need a special tool to remove the pitman arm? Thanks again!!!
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
As a follow up messicks found the part at a warehouse that specializes in discontinued parts. They are supposed to have 2 of them? Won’t know for sure until Tuesday. I’ll let you know how it comes out but I have a feeling I’m over my head on this one. Old and stupid do not make a good combo šŸ™‚ BTW why does it cost $20 plus for shipping a part that probably only weighs a couple ounces?!
Pau7220
Aug 1, 2017
785
280
Scranton, PA
Because they can. I've given Colemans more business for that reason.
Btw, Jones Farm Supply is the warehouse I'm sure they're referring to. Shipping is $5.95 buying directly.
Yes, you will need a pitman arm puller. Harbor freight, or borrow from auto zone or advance.
The face of the sector shaft and pitman arm may (should) be scribed or marked. If not mark it.
The gear on the sector shaft where it hits the ballnut may have a paint mark. If not a drop of paint pen will assure getting it right. If you miss by a tooth you won't get full turning range.
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
What about putting the sector shaft back in? How will I know that it is positioned correctly? Does only go back in on way?
Pau7220
Aug 1, 2017
785
280
Scranton, PA
It can go back in multiple ways, but only works one way. Easy to figure out on a work bench if you've done it before. First timer on the machine makes it a little more difficult.
Take a look at the post again... a dab of paint pen on the ballnut and gear if not marked. Or, use a sharpie, pics, masking tape with an a mark, etc. ..... Whatever works for you.
Looking closely at your pic the face of the pitman arm and sector shaft is already scribed.
5,255
1,057
Study the attached part of the WSM closely.
Pay particular attention to page S7-27 regarding the orientation of the two sector shaft seals. The internal one needs to face inwards and the outer dust one faces outwards.
This internal seal is the one labelled as a gasket in the Messicks parts illustration.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
True... it almost looks like you're installing the outer dust seal backwards, but it's correct with the lip outward. (Thanks Dave)
Why they call the inner seal an oil seal in the WSM, and a gasket in the parts diagram is beyond me.:unsure:
And as stated in the other thread... keep it clean! Pressure wash before removal/disassembly if possible.
modeladay
Mar 25, 2016
117
10
Lincolnton, GA
I hate to Be a pain in the ass but which side of the seal is the outer. If the flat side is the outer than the dust seal is in backwards?
