Hello everyone, new to the forum and did a search to see if there was another problem consistent to mine but came up empty.
about a month ago I discovered a very small leak in one of my hoses that went to my loader. Before I could repair it my hydraulics started acting up.
My symptoms are that as long as the RPM's are below 2200 everything works fine. But if I hit the end of either the 3 point hitch travel on the way up, the top of the boom or bucket travel then everything stops working. I know that there's a release valve in play with the normal operation that kicks in when you reach these stop points, but some how that is now being triggered by my described symptoms and not releasing. The only way to get it to reset is to turn the tractor off and restart. I did a slow rev-up and again right about 2200 I can hear the pump/engine change and the hydraulics stop working.
- I've replace the leaking hose and do not see any additional leaks. I then made sure the system was topped off. (Didn't really need anything since not much leaked).
- Did a complete Hydraulic fluid change to include filter and suction screen cleaning. (screen was almost completely void of material.
- Removed the relief valve and checked for anything unusual in the spring or shims but nothing. I'm not sure how to service the valve and haven't seen any related video's info in internet searches.
- I've also disconnected the 4 Bucket lines to see if it was perhaps related to just the bucket but the 3 point hitch still acts up.
