Air in fuel lines question
2,994
This is probably a stupid question, but here goes (someone told me once there are no stupid questions... )
If one would run his tractor out of fuel, and simply add fuel, and if it started, would there be any need to bleed the fuel lines of air afterwards? Say after the tractor ran for 15 minutes or longer.
I can understand the need to get air out and fuel into the cylinders in order to start the engine, but once the engine is running, would not air in the fuel lines disappear?
My gut says it would no longer be an issue...
Roadworthy
L2501 HST
Aug 17, 2019
1,649
527
Benton City, WA
Regardless of what your gut says it could still be an issue, as can inadequate bleeding of the lines. This is not necessarily true for all tractors. Follow the manual for your specific tractor. Some need air bled off and some do not.
armylifer
Mar 26, 2013
2,061
787
Thurston County, WA
In my experience if the engine continues to run then there is no need to bleed the lines. If there was any air in the lines still the engine would stumble and probably quit running.
5,248
1,924
speaking of mechanical injection only right now...like on older tractors (pre tier 4).
when you run out of fuel the fuel lift pump forces air into the injection pump, then the injection pump pumps air into the lines and injector nozzles, then the engine blubbers a few times and dies. So what you would do at that point is to refill the fuel tank and loosen the bleeder screw. Most all Kubota mechanically injected engines will have a bleeder of some sort, typically on the injection pump's inlet or at least very near it. When the bleeder is loose, it allows air to be expelled, which allows fuel to be drawn into the lift pump, then pumped from lift pump to injector pump, then the injection pump picks up a little fuel and forces it at high pressure through the injector lines and finally to/through the nozzles. Once fuel is into the nozzles, it doesn't take long for the engine to start running again.
Some tractors are a real bear to bleed! I can think of a couple, and one being L2350/L2500/L2600/L3000. Run one of them out of fuel and you gotta jump through hoops to get them started again, so the best thing is to not run them out of fuel. Easy enough?
Tier 4 engines are almost all common rail injected, like most all newer diesel trucks are.. Anyway, the way to bleed those (kubota) is to loosen the little bleeder on top of the fuel filter housing, turn the key on but do not crank the engine. Let fuel run out of the bleeder for a few seconds, letting the air stop flowing. Once no more air, tighten the screw back up, and leave the key on for a few minutes to circulate fuel through the system. That little electric pump also forces fuel into the fuel rail at very low pressure, enough to get most of the air out. Common rail isn't as sensitive to air in the system but it is extremely sensitive to dirt/water/gas/etc.
where I see screwups is guys loosening the injector lines at the pump. Don't do it. The delivery valves are all timed. When you attempt to loosen the lines that have been stuck on there for however many years, the delivery valve has a tendency to turn as well, and at the point if it does turn, you remove the pump from the engine & send it off for repair. That's why Kubota put a bleeder on them but people see this stupid stuff of loosening the lines on TV gold mining shows and think hey I'll do the same thing. Wrong. They do it wrong on TV too in a lot of cases.
2,994
Thanks guys for taking the time to reply. And especially lugbolt for all the detail.
So am I correct in assuming if a tractor runs OK after adding fuel and NOT bleeding air out of the system, there in is no longer a need to be worrying about it?
I do not have an issue. Just intellectual curiosity I suppose. Driven by a comment in a different thread.
5,427
I think what happens sometimes is that while running the tractor out of fuel, a whole lot of crap in the tank can get into the fuel system that wouldn't otherwise get there.
Causes filter, lift pump, injector, etc. problems beyond the air introduced.
The obvious solution is to bleed, bleed more, etc. when the problem is something else.
Certainly a testament why running a diesel out of fuel is bad news...
armylifer
Mar 26, 2013
2,061
787
Thurston County, WA
To answer your question in a direct manner, if you are not experiencing any running issues, then you dodged a bullet and all is good.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,147
1,266
Near Lancaster, PA, USA
I ran the Ford out of fuel a couple times. It has a bleed screw and it works very well.
One time when it ran out, I had fuel but no tools. I filled the tank and cranked till I thought the battery would die. It finally started and ran OK after some sputtering.
