I purchased this tractor L4400HST used and had everything checked out and serviced before I had it delivered.
Now I'm coming up on the 200 hour mark (since I bought it, 780 total) and in my manual (attached as photo) it says I need to replace the hydraulic oil filter, at 200 hours. As you can see from the instructions it wants me to pull the drain plugs (all 4) to do this. Now, Ive never been accused of rivaling Einstein, but it would appear to me that in so doing the oil will drain out, which really turns into an oil change, not a filter change. (Mind you the OIL change is to take place at 400 hours, not 200).
Am I missing something? Will it only drain a small amount of oil--enough to remove the filter? Should I skip this until I do the oil at 400 hours?
BTW... contacted dealer and guy in parts told me to "just take the filter off quickly and put the new one on quicker and shouldn't lose much fluid".
