bx tractorjoe
sooo.. been looking for a cheap lawnmower, so I don't always have to use my l2501..
Found this old gal for a song.. and got them to deliver it..
Now I know why it didn't sell at the cheap price to anyone else.. but it was cheap enough and I enjoy fixing up old tractors soo..
First issue, which I did not even notice till I got the mower deck on, is the oil dummy light is on.. i pulled the valve cover cap and i can see oil squirting from the rockers so i know it has oil pressure, that and the engine runs very good with no knocks, does smoke a bit bit the hour gauge says 2156 or so.. and I'm sure its been replaced the chrome ring is to nice to be original compared to the rest of the tractor.
2nd issue, the deck, from the paint is not original, and is at least 60 inch, see pictures of the tag, after putting it back on, (what a pita!) I noticed it had been modified to fit, the 3 point also does not lift it due to the bars from the 3 point to the deck are just not right.. is all I can say.. again after putting the deck on and mowing for a bit in 95 degree weather I was done..
It also seems to run a bit hot the thermostat housing was 198 degrees after mowing for 15 or so minutes.
The oil was nasty.. i changed it, no new filter so will change it again once new filters arrive, fuel filter is also nasty..
I think the rear end axle bearings are worn.. the wheels kind of shift when you start to move just a tiny bit.. but could just be me...as it was hot.. will look into that more..
I plan to add a oil pressure gauge, I am pretty sure I have one laying around..
This should be a good project.. ot sure does mow nice and runs great even with all the issues..
Tomorrow I will dig more into it..
