Bh70 bucket cylinder assembly
Tomztoy
L3901 FEL BH Grapple Post Hole Digger Flail Mower Back Blade Rake Stump Grinder
Oct 28, 2016
21
Cleveland TN
I currently have a BH70 with a bent cylinder bucket rod and cannot get my dealer to put one on backorder. So I am looking for alternatives.
Does any one have the specifications for a BH70 cylinder bucket assembly? I have called a half dozen dealers trying to locate a 7K506-43010 complete assembly (and/or parts) and was repeatedly told "gook luck trying to find one". A major on line dealer said that there are none in the US. My own dealer parts dept. said "they have stopped making them". My B2601 was purchased new 2 years ago besides the fact that Kubota stills sells them. So getting local dealer to help locate something is not an option. I did ask a few of the calls about current spec's on cylinder but got no where so I an reaching out for some direction.
I there any place that may sell a non-factory replacement?
Any suggestion/info is greatly appreciated.
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
It's still listed on the Canadian website. So are all the parts. Maybe try an on-line place like Messicks?
BigG
Sep 14, 2018
1,953
774
West Central,FL
Can you get the measurements and buy one on line? The local hydraulic shop could probably measure it to get one. You might have to lengthen or shorten lines but I would think it is doable. More than likely it would cost less than Kubota.
5,515
2,228
I ran a search on 7K506-43010
found that Sowell Tractor in Panama City, FL "MIGHT" have one. It'd be worth calling & see if they'll ship it. That was the only listing. All warehouses show zeros, so it would be backorder only and knowing Kubota, you might or might NOT get it. A lot of times when there is all zeros in all the warehouses, they're not likely to get another one until they get a run of orders for the same part.
Tomztoy
Oct 28, 2016
21
Cleveland TN
Called both Sowell and Mesick's without luck. I am pretty much at the point of searching for "something really close".
Thanks
Tomztoy
Oct 28, 2016
21
Cleveland TN
That is the direction I am heading.
Thanks
baronetm
L3901HST w/FEL, 3rd fnct. BH77 BH, 5' Bushhog, 6' BBL, 42" Forks, WoodMaxx WM-8H
Apr 19, 2017
122
12
South Central VT.
Try a reputable machine shop, they may have or be able to purchase the cylinder rod material and machine the rod to match your damaged rod, i.e. don't forget to tell them you want it without the bend, don't laugh I have seen it done.
Luckystars
M5950 M1840A RTV900 CLUB CAR CARRY ALL 1
Mar 1, 2018
98
Webster FL USA
Here in Florida we have Central Hydraulics. They rebuild cylinders or sell replacements. End to end distance, length of stroke, bore, end size and connections and hose connections all will matter but these guys seem to have or make everything. There has to be some place like this near you.
3,995
2,471
Sounds like you've tried to order just the rod also, right? You should be able to find a shop to make a new one or possibly straighten the old one. Not to pick on you, but how did you bend it? You're not the first and I'm trying to learn what not to do. I don't have enough years left to make all the screw ups myself.
BigG
Sep 14, 2018
1,953
774
West Central,FL
You will have to work faster.
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
Both of my dump cylinder rods bent when the crappy welds broke on the dump stops. PO was anything BUT gentle ... and all of his repair methods included duct tape and bailing wire. Straightened them with a hydraulic press and V-blocks.
3,995
2,471
Thanks. Good luck.
Teejohnowens
Kubota L3650DT
Jul 18, 2020
Home
hey man i see you have the same tractor as i do. Im having abad problem with my steering column leaking under the steering wheel. Have you ever had that problem?
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
Answered in your thread.
