L4200 GST Cable broke
johndeerebones
B7200 HST-D RC-60-72, L4200 GST MFWD with FEL
Aug 17, 2020
109
My L4200 GST is dead where it sits. Won't move. One of the GST cables broke and it won't shift. Question is, it is Sunday and can't figure out if I can replace the cable or assembly.
10,941
I think the bigger question should be why you think it's sunday... it's monday evening.
You will need to replace the entire cable assembly as it's not sold in individual pieces.
johndeerebones
Aug 17, 2020
109
I took the lower shift off the trans so I could manually shift it and move it, turns 360, so no idea what gear I was in but it felt like 8th. Anyway, the cable sheath is there, cable broke. By looking at the bottom it is a plain cable. Haven't taken the upper shifter apart yet, but are you sure I couldn't fashion a replacement cable?
10,941
Yea I'm pretty sure making that cable is about impossible.
But please if possible prove me wrong, as that assembly is expensive!
johndeerebones
Aug 17, 2020
109
Wish me luck! Got cable and clamps like the cable ends. Can a gst owner take a picture? The cables are different length. Sure suck to get it together and on and have it backwards!
Pau7220
Aug 1, 2017
785
280
Scranton, PA
Keep us in the loop with pics. Looks like mine and and I have no idea if it's ever been replaced. Good luck🍀!
johndeerebones
Aug 17, 2020
109
Been all over to find the cableadjuuster, mine was broke. I know its slotted, but no reason that won't work. I was putting the upper shifter together last night and one stripped
(impact), got a couple grade 10 bolts and nuts. Not happening now! Used these cable clamps ground down and filled with solder.
johndeerebones
Aug 17, 2020
109
Got it together. Needs adjustment but it got dark. The black sheath was ok, cable, a couple stops, cable adjustment bolt, a couple bolts and nu tr s and probably a good days work (after all the parts chasing). Grand total of about $20. Kubota can stick their 700 dollar assembly you know where🤪
Pau7220
Aug 1, 2017
785
280
Scranton, PA
Love to see stuff repaired for pennies on the dollar. Great job!👍👍
airbiscuit
Mar 18, 2021
404
461
NW WI
I know this is an old post, but a member on the TractorbyNet Forum has a GST Cable problem. He could benefit from your experience. Here is the thread
https://www.tractorbynet.com/forums/threads/l3010-gst-will-not-shift-out-of-neutral.435422/
Frito
Kubota L4310, GST, ROPS
Jun 2, 2025
Oregon
Thank you all for documenting the repair on this -- I think I got my cables at the wrong length and my original is pretty shredded although I tried to match the length. Any advice on how to find the length of the cables? One cable is still in tact and looks to be 34.5 inches.
johndeerebones
Aug 17, 2020
109
If i rember it was around 35". 34.5 probably right. I eventually replaced it. Needed the tractor quick.
