Help finding a mechanic in Connecticut
JMF
kabota L2850
Jul 20, 2020
Shelton, CT
I have an L2850 that needs a new clutch I have a price of $6K to do the job splitting the tractor and replacing clutch. looking for someone that might be able to do the job for less. It is an older tractor and not sure if it is worth putting more that $2-3K into it? Other than the clutch the tractor runs well and the hydraulics are sound.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
709
331
Herald Calif.
Hello
I would fly from California to Connecticut and put a clutch in your tractor for half that. $6000 sounds a little out of line. 8 hours labor with no loader plus 3 or 4 hours depending on type of loader. Plus parts. Even at dealer labor rates of $100 to $135 that is a little high.
Good luck Lance
Daveinwestmi
L3560 ROPS, BX2380
Jul 6, 2019
14
Kalamazoo, MI
I think 6K is the "I don't really want to do it price but if you insist"
JMF
kabota L2850
Jul 20, 2020
Shelton, CT
Hello
Good luck Lance
Thank you for the reply, I am trying to find a mechanic that might be able to help me without having to pay the dealer service pricing. I have read some blogs that some people prefer to do the job with the loader on have you ever done it that way?
007kubotaguy
Dec 23, 2012
709
331
Herald Calif.
Typically trying to do a clutch job with a loader on does not make sense. It may be possible with the type of loader you have. I would not do it that way. It's best to get it out of the way so you can play the tasks in a timely manner. Good luck. Lance
L35
Jun 13, 2010
715
831
CT
I know of a shop in Wallingford if you are close by
L35
Jun 13, 2010
715
831
CT
I am in Shelton so Wallingford is fairly close . Do you have aname of the shop or a person I can contact?
Have you tried to contact al Preston’s garage on Howe ave? That guys been there forever may be worth a shot.
SidecarFlip
Banned
563
Hello
Good luck Lance
I bet the shop rate out east is more than 135/hour. Probably like 150 at a dealership. Everything including the cost to live is higher out there..... and, a clutch job on an older unit usually entails finding other items that need replaced / renewed so they may be factoring in the unknown as well.
BigG
Sep 14, 2018
1,953
774
West Central,FL
I have a Kubota mechanic that runs an ad on Craig's list almost all the time. So check Craig's list and Face book and if you have doubts about the mechanic ask for references. If the refuse to give references you do not want them. Any brand of dealer should be able to do a clutch.
al b
l345dt, l48, l2550dt
Feb 15, 2012
53
Ct
I did my L345dt. left the loader on, it helped steady the front while I rolled the rear section on a floor jack. I disconnected the loader from the rear axle only. I had to brace the motor up good so it couldn't move.
