Kubota B7000 Lift capacity
kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
Anyone know the lift capacity for the B7000??
I do know that the Woods mower RM400 uses two chains to keep the front of the mower and the three point arms locked to height. From that I take it the hydraulic pump will not keep the arms locked at height with the mower weight on the arms?? The chains go from the three point lower arm hook up to the top link pin where two adjustment links go onto the pin IMG_0426.jpg IMG_0427.jpg
9,267
The lift capacity is probably very similar to the B7100, so somewhere around 400lbs.
kaze
Will the B7100 hold at the height you set it with weight on it or slowly sink? The B7000 I have been using the mower without the chains. and sometimes have to bump it up. This year put on chains.
torch
Jun 10, 2016
2,797
1,028
Muskoka, Ont.
Virtually any hydraulics will slowly sink. The only question is time. My B7100 3ph will sink from fully raised to just off the ground in about 24 hours with a 425 lb snowblower hanging on it.
