Need a welding opinion-
Yooper
3901 LA525
May 31, 2015
1,733
910
NE Wisconsin
Just a reminder that a grinder is your best friend. If you go with the nut I drill out the inside to clean up the metal. I like the flat stock idea. A fillet weld is stronger than a plug weld
3,534
Yeah, I had a 4pt socket, but 3/8 drive instead of 1/2, but it split. (that started the rounding off process)
I had a 1/2 drive 4pt, but at home 150mi away.
I already have a replacement plug with a hex, so next time I can use a six point socket.
If I ever get this one off, that is.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,439
636
Richmond, Virginia
Sort of after the fact but... I have to wonder why a drain plug was so over tightened to begin with. It only needs to be tight enough to not leak. Finger tight and a half a turn is usually plenty. If a plug leaks when snugged, try a new plug. If that does not stop the leak, used a tiny dab of sealant on the threads, being aware that the sealant often acts like a thread lubricant and that means to use less torque than with dry threads.
3,534
When I was starting re-assembly after rebuilding this backhoe, my knot-head BIL was over and wanted to "help".
I looked around and decided putting in the drain plug seemed like something he couldn't screw up.
Boy, was I wrong.
Now I'm wracking my brain trying to remember what else he might have done. I don't think there was anything else, because the rest was bordering on actual work, and he's allergic to that.
I usually use a little dab of teflon-based pipe thread sealant for such things.
I think the problem here was a very clean steel plug and a very clean steel spigot, grossly over tightened.
SidecarFlip
Banned
563
Boy, was I wrong.
Maybe Mr. Knothead put threadlocker on the threads????
10,945
You needed the, "It WILL come off/apart pipe wrench"! 😜
dlsmith
BX2230, LA211
Nov 15, 2018
1,359
1,058
Goshen, IN
THAT"S why the proper socket( 4 sided) is necessary. The vicegrips only grip 2 opposite sides, socket fits all 4. BTDT... I now own 3 or 4 sizes of them 4 sided sockets. They're one of those tools you never think you need, 'only collect dust'.,naw I don't need them ...BUT.... all it takes is ONE PITA pipeplug and you'll be going to the store next time....
heck you've got to buy another plug so while you're in town..... buy the plug THEN goto store and get the proper socket...
What he said.
Use the right tool to begin with.
Makes life much simpler.
CaveCreekRay
Jul 11, 2014
2,631
106
Cave Creek, AZ
Hope ya got a spare plug when you get that one out or that'll be another trip... Good luck!
3,534
Yeah, I've got two brass ones with the square head, and a brass one with a hex head.
3,534
UPDATE:
I got the plug off! Giant pita, will report in detail when I get home in couple days, where I can post pics.
3,534
did you have to weld a nut onto it? thats usually my go-to
Used Bearbait's idea and welded a strap on the stub. Pics and details in a couple days.
5,504
Ya know way back in the day in here, someone posted about heating the bolt up and then letting a candle wax melt in the exposed threads. He said the wax was drawn by the heat in to the threads and made bolt easyer to remove,, do it work I dunno
Ltk
Kubota L2501 HST
Jul 11, 2020
Kentucky
not a bad idea! i usually permanately weld a nut to those pipe plugs after first removal.. makes life much simpler
3,534
OK- back home again, so here we go.
After heating it again and trying the candle wax method with no luck, I dove in with the welding method.
I took a 1/4" x 1 1/4" strap 30" long and ground off the galvanized finish.
Then I drilled a 5/8" hole that just fit over the stub, and heavily countersunk it.
Shielded the nearby hoses with aluminum.
It was tight getting the gun in there, but I piled up a bunch of material to make sure I got it plenty hot.
