Kubota Part Numbers are XXXXX_XXXXX so I don't know what part you're looking for.Howdy. As the title says, do I really need this part And if I do could someone please tell me where to look for it. I'm not having any luck locating this part.
R. Smith
I think #12 is a locating dowel pin, not #14.Looks like a locating dowel pin to me.
Thank you. Thank you. Having the correct part numbers is great. Maybe I can finally order the part.Maybe this document will help. Illustrated Parts
Copy of WSM: WSM V1505
Perhaps a newer version of WSM: WSM Newer?
Thank you. I wasn't smart enough to also ask the purpose of the part. Now i know.That pin pipe moves oil from the block to the head for lubing the valve train.
Putting a dowel pin in place of it will destroy the top end.
Not putting a pin pipe in it will likely cause it to leak oil.
You need P/N 16241-33650![]()
Slow but sure. Right now while I'm waiting for the two oil seals and that pin, pipe to arrive I'm working on the old vertical band saw mill the engine belongs on...Curious to learn how the rebuild is working.
I had a couple photos in a Facebook group. Only a few postings. https://www.facebook.com/groups/105173746998391/Ok.......P.ics of the Saw Mill.....Theres a few of us that are into that.
Its not like you don't have time...while your waiting...jk
