Kubota L3710D
Waynyak
L3710D
Jul 23, 2020
Medina Ohio
Can someone please tell me the part number for a front end loader for the above model number. I am looking to buy one used. Please advise.
UpNorthMI
May 12, 2020
849
568
Up North, MI
Tractor data .com list a LA681 loader for a L3710 tractor
10,700
LA681, LA682
You might also look for aftermarket loaders, as you'll have better luck finding those.
Woods and others made very good FEL's for those models.
tbk5
L3710, L3010, ZD1211, RTV900xt, GR2100, lots of 3pt equipment
Sep 24, 2013
184
94
Central AL
I am in the same situation. I am wondering if a LA481 from an L3010 will fit on an L3710.
My situation is that my L3010 was totaled by fire during transport via a commercial carrier when I moved. The fire destroyed the back end of the tractor. The engine and loader appear to be unaffected. The backhoe is also fine. I found a reasonably priced L3710 nearby for a fair price. I know the backhoe subframe part number is the same between the two. Woods loader spec sheets indicate that all the Woods loaders are interchangable. I can find any info on the Kubota loaders. I would like to move the loader from the 3010 to the 3710. Any advice?
tbk5
Sep 24, 2013
184
94
Central AL
Here is what I found from a woods cross-reference document:
tbk5
Sep 24, 2013
184
94
Central AL
I was able to fit the 7500 backhoe with subframe from the L3010 to the L3710. Using the LA 480 frames required that I add an extention to bolt the frame bar to the rear axle housing. It worked well to dig a 400ft trench to run water and power to the new barn.
I am now looking for an LA 68(0,1,2) loader. If I can't find one, I'll weld an extension to the LA480 brace. It is mostly used for light work.
