The mower was dropped off yesterday evening. I had a little time to mow with it. I was rather disappointed as the cut quality was just awful. Each row was uneven. The front was set to articulate and I set it to the locked position. The cut did not change. It was almost dark and I parked it. But, before then, I was thinking it might help to move the wheel rollers down. And when I parked it, I thought about the tire pressures.
So, today I moved the rollers all the way down. The tires pressures were checked. Back is supposed to be 12 psi and the front 24.9 psi. One back was 29 psi, the other 9 psi. Both fronts were about 8 psi. I got that all sorted out.
Mikester, I decided to take off the covers. I just hate those things. I even mentioned it to my salesman, who dropped it off for me. He said people do it all the time on those mowers. So, I took those off, to discover grease everywhere under the covers. I guess the spindles were overly greased. I had to clean that up. After that, I got to mowing. I was pleased. The cut was excellent.
I can cut so fast. It is a shame my yard is not smooth, but I probably can cut in half the time now. I even cut some very thick grass in my back field I normally brush cut. I heard the engine changed tone just a time or two cutting in the field and it was blowing out a bunch of grass because I had the mower on level 1.5.
So now, I am happy with the mower. I hope it will continue to be a good mower.
