You need a cheap multi meter to measure the battery voltage with the engine running.
In all likely hood your voltage regulator is no loner working unless you can find a damaged or disconnected wire.
There are a number of versions of your machine so if you get to the point of ordering a new regulator, be certain to have all model and serial numbers with you.
