Tilling technique
Rigger Dave
L3301
Nov 11, 2016
25
Camden, NC
I’m tilling a 40x40 plot for garlic this fall. At the end of the run the tiller leaves a large divot. Not really a big deal but would like the whole plot to be level. Any advice or is it just how it is.
Thanks in advance,
Dave Richey
MINICUP28
B7610, KX-018, RTV-500, JD X758
Feb 21, 2019
96
COBLESKILL, NY
IF YOU HAVE ROOM TO GO IN BOTH DIRECTIONS, I USED TO GO THE OTHER WAY TO FILL THE DIVOT AND THEN NEAR THE OTHER END LIFT THE TILLER OUT SLOWLY BEFORE THE END.
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
103
22
Nampa, Idaho
In my case I have has good luck with tilling all one direction on the final plot till. This leaves your divot for each row tilled all on the same end of the plot. Then I make a final run by tilling down the line of divots so that when you get to the end of your plot everything has been leveled and there is only one divot left for the whole plot and that is easily raked out by hand if needed.
Creature Meadow
Sep 19, 2016
1,064
135
Central North Carolina
Disking or tilling I do a clean-up pass at the ends as I never lift or lower in the same spot always some at the start or end not done. This adds a nice finished look.
67Truckin
BX1800D
May 25, 2016
78
Pleasant Plains
We run a tilling service with a 48" tiller. We run it all one direction starting on the right side to leave no tire track. Then we run a pass across the end to fill in the divet. Never a complaint in years now.
NHSleddog
B2650
Dec 19, 2019
2,149
1,831
Southern, NH
It all depends on the ground. Sometimes a single pass over last years garden is all it takes. Sometimes it is a ground that needs multiple passes. If that is the case doing it in several directions will give you better results.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,199
128
Coyote Flats,Texas
Why not as one approaches end of the pass slowly raise tiller therefore virtually eliminating the divot?
BigG
Sep 14, 2018
1,951
770
West Central,FL
As the others have said it is easier to run in one direction and have the divot along the one edge. Then run at 90 degrees to fill in the divot. Everything will be tilled to the full depth. And as you have suggested as you near the end of the final row you lift the tiller as you approach the end to leave none or a very little divot to fill in with a hand rake. This will minimize the hand work and give you tilled earth all the way to the end of the garden or yard.
67Truckin
BX1800D
May 25, 2016
78
Pleasant Plains
We always do a double pass as deep as possible for our customers. The dirt looks like it is poured out of a bag and 6-8" deep with no green showing ever.
