Bush Hog 286 PTO shield
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
A couple of days ago I posted about a vibration problem with my bush hog. After posting a video it was (correctly) pointed out to me that I need a shield for my shaft.
I have searched the "inter web" for a couple of days now trying to find an exact fit PTO shield for my 286. Does anyone know which shield will fit this cutter? A part number, generic one or direct link to one that will fit?
5,236
1,018
Looking on the Bush Hog web site I find this.
You will want part #24.
Shield
I would call before ordering
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
You will probably not find the exact shield for your driveline. They are normally cut to fit. They're plastic so a hacksaw goes quickly. You do need to cut the same amount from each half of the shield just like sizing a PTO shaft.
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
Shield
Thanks Dave. Just called and they want $200.00 for the COVER. I might as well get a whole new shaft for about $290.00.
SDT
multiple and various
Apr 15, 2018
3,256
1,042
SE, IN
Shield or otherwise, your vibration is caused by something else.
SDT
5,236
1,018
I am surprised at the $.
In Canada in 2018 I paid $48 for the complete pto shield. Comer T50 series
Having a second identical shaft provides you with a backup. Less critical on a rotary cutter but necessary for my snowblower.
Make certain before you install that the length is correct. Lots of youtube video's on cutting pto's to length.
PTO
If you have not solved your vibration issue, I again suggest you remove the blades and see if the vibration disappears.
