3PH bent? Maybe
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
I don't pull loaded trailers but a trailer mover almost required equipment when mowing or pulling cement filled rollers
5,264
I got one of these years ago to keep the pull point low. Replaces the plate
Could be fabricated easy enough.
PapaJ
L2501 HST
Apr 28, 2020
284
106
TX
This is the one I ordered from AI2. Be here next week.
imnukensc
BX2380
Sep 10, 2015
688
591
Midlands of SC
This is what I do. Seems a little more versatile than a 2" receiver hitch for my purposes. If I'm pulling out bushes/shrubs/small trees/stumps, I use the clevis. If pulling the boat trailer or utility trailer, then I use the appropriate hitch ball on the 3 pt.
2,968
I use something similar with my BX. One possible issue is that the 3PH does not apply down pressure, and in my case there is the chance my dump trailer could cause the 3PH to lift, and I would end up pulling from a point above the center of the rear axle. Has not been a problem, but could be.
I tend to load the trailer so I get ample tongue pressure. Trailer is 5x8.
The other side of the coin is once in position to dump, I can raise the 3PH and get a bit more favorable angle of the dump bed.
PapaJ
L2501 HST
Apr 28, 2020
284
106
TX
I have something similiar, but it is solely for moving empty trailers.
