I have a 2018 L3901 that I would like to fit armrests on, my seat has the 3 dimple locators where the attaching screw hardware should go. I am unable to get a correct part # that will work, has anyone been successful and can share this info? I did just post about adding armrests to my MX5800 which went very well.
I tried purchasing part "Briggs & Stratton 1687810YP Arm Rest For Simplicity Snapper",
I found prior posts on the forum that members had used this part but they did not fit my tractor. I contacted Messicks and gave them all of the measurements for the location dimples and my seat part # but they did not come up with a solution other than buy them aftermarket!
The 3 location dimples for mounting on my seat form a triangle, here are the measurements and seat info:
My seat has a number on the base: 25595A (1128-0140)
Hoping someone can help as several other forum members were looking for the part # too.
- Horizontal direction (below seat base) 4-15/16” between dimples.
- Vertical direction (behind back support) 4-5/8” between dimples.
- Diagonal line from lower front to high rear 9” between dimples.
