Typically you need a special puller.Please, how do I get behind the dash to replace my 1985 voltage regulator? The steering wheel is not easy to get off.
Thx, Dave. The mechanic who came to tune it up said it was shot but didnt have the part to effect the repair. I cant afford to have him back out to replace it, so I will make the switch, God willing!Typically you need a special puller.
First there is a U shaped piece of steel that slides under the steering wheel for the puller to pull against.
Then the puller removes the wheel.
See attached page from B7100 WSM which is likely the same.
If I was in your situation I would be trying to separate the steering column close to the steering box but this is an educated guess.
Why do you think your regulator is bad?
Sounds right... the mechanic told me to whack on the steering wheel bolt with a punch also, to coax it loose. What do you think?Most times, removing the cover plate and then the nut and applying some penetrating oil like PBlaster and letting it soak in overnight and then some gentle persuasion with a soft mallet on the backside of the steering wheel will allow removal.
If you are going to skip the puller then don't go bashing on the plastic underside.Let the PBlaster soak in for a day, I think it will come off with a mallet on the underside (after you remove the nut of course.)
Follow your mechanic's advice.
Loosen the nut until it is flush with the top of the shaft, (in order to protect the threads), get in a position where you can use your lower legs to apply upward pressure on the wheel.
Now, while continuing to apply upward pressure, give the nut and top of the shaft a sharp hammer blow with a real hammer (not a carpenter's hammer).
With luck the wheel will pop up from the splines.
Thank you!Let the PBlaster soak in for a day, I think it will come off with a mallet on the underside (after you remove the nut of course.)
Sorry I thought you said to use a cinder block....Did I say 'Bash'? hell no I didn't. I said....
" and then some gentle persuasion with a soft mallet on the backside of the steering wheel will allow removal.
You need to read my comment again or get glasses....or both.
No, Harbor Freight recall jackstand.....Sorry I thought you said to use a cinder block....
