LED lights L3560 LE
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
I'm sure many have already done so. I plan to add a light bar under my ROPS. I've got the parts it's just a matter of taking the time.
SidecarFlip
Banned
563
I changed all my filament bulbs over to LED on both my M's with the exception of the turn signals and hazard flashers. LED bulbs and conventional flasher relays don't get along well.
Bmyers
May 27, 2019
3,624
4,907
Southern Illinois
If you want a plug-n-play option here is a link:
They are a little pricey at $95, but the are a direct replacement for what is on your cab and comes with the correct connector.
Hillbilly77
39
New York
I mounted a set to the front brush guard.
I had a thread on it a while back.
Cstock5468
L3560 with loader, BH92, LP post hole auger, LP box scraper, Front PTO snow blow
Apr 16, 2020
Plainfield, NH
Has anyone added LED lights to th front of their L3560? Separate lights or light bar?
For my L3560, I will be replacing all 4 work lights with 15W LED lights (5 amp total for all four) with much higher lumens. Also will be adding LED light bar in front as headlights do not help at all when working at night or in dark conditions due to front attachment. I expect the front light bar bracket tomorrow that mounts to the front work lamp brackets tomorrow and have a separate power line, fuse and switch for the light bar. I took the cab roof off L3560 in order to run wire. I need to figure out best place to connect to 12V power beyond the battery terminal itself. Any suggestions, ideas or experience share is very appreciated. If this works out well, I may add a back LED light bar also. I got the light bar bracket from Specialty Repairs in Canada that makes these easy to install brackets (do not need to take cab roof to mount). I may not need the front work lights as the LED light bar has floods on the sides and projector beams in the middle. The light bar is rated at 8.3 amps, so best to have a separate break for that even though the added amps for all lights is 13.3 on a 15 amp circuit (fuse). Any and all input appreciated.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
in summer months, they will attract bugs
Willbeone
L3560HSTC LE, LA555 loader, Scraper/grader, Woodchipper, Backhoe.
May 19, 2021
15
Oklahoma
Thanks for tip on Tiger Lights! Just purchased a L3560HSTC Limited and am in the process of outfitting. $95 isn't that pricey when you consider an OEM light is $94 plus the cost of a bulb at $34! Are the front and rear work lights the same? It looks like all I would need is the 4 lights and 2 switches to have all LED work lights.
