you can't charge by pressure alone. That is the wrong way to do it. Many do, but it's still wrong.
if someone tells you that refrigerant level "gets low normally" they are wrong. If the refrigerant charge is low you have or had a leak, or someone's deliberately discharged it. The latter being the most common because of the youtube mechanics spouting off incorrect information.
Most of the kubota a/c systems are to be evacuated properly, then charged by weight. If it calls for 2.1lb of refrigerant, add 2.1lb and you're done.
Charging by pressure alone will result in a lot of things, and one of them is a potential for serious injury, the other is spending some money.
A good a/c tech is going to have a PT chart handy to CHECK the pressures, but he won't be charging via pressure alone.
where I see most a/c problems is with the condenser, the evaporator, belt, and then a hack job "mechanic" playing with the system, in that order of frequency and severity, with the latter becoming more common and more expensive to properly repair. Had a L5030HSTC in a while back, suffered from a leak originally, owner's friend fixed the leak, added refrigerant, and sent it on. No evacuation, just left the air in the system. Ate up the expensive scroll compressor, and of course contaminated every single component of the system requiring replacing. $$$$$$. One of many examples.
Kubota uses a lot of scroll compressors. They work awesome and last a LONG time with many fewer parts than a piston compressor. HOWEVER; they are extremely intolerant of moisture and contaminants in the system also as all compressors intolerant of liquid refrigerant reaching the compressor. The biggest downfall is that they are expensive for no bigger and no more complex than they are.
another good example is my "neighbor". Dodge pickup. He brings it by the house says his a/c ain't working very good. First question is "has anyone worked on it?". Yeah, he said he bought a gauge set and the pressures were way high, over 400 on the high side so he "let some out" (illegal and I could have turned him in and been eligible for a hefty reward, but I didn't). All it was, was that the condenser was plugged with mud/dirt, so he grabs a set of gauges and reads high pressures, which is normal because the condenser is plugged. That's not the smart way of doing a/c work. That's the expensive way. A garden hose and about a penny's worth of water would've solved it in 5 minutes' time.
and yes deliberately discharging refrigerant to the atmosphere is illegal and if an offender is either caught or "tattled on", the "tattle tale" can get a nice reward if the offender is found guilty. All in the 609 books for those that want to read.
