B B8200 Owner New member Apr 4, 2020 25 3 3 Kenosha, WI Jun 10, 2020 #1 I’m currently doing a Value job on a B8200 HST tractor that has a D950 Diesel. I was looking at the assemble manual and can’t figure out the Torque sequence for the Head. Does anyone have a diagram and torque specs?
N3BP Active member Equipment B7200DT, B7200HST-D, L2900GST, L3010 HST TLB Sep 20, 2016 473 202 43 Lebanon, PA Jun 11, 2020 #2 Sequence attached....47.7-51.3 FT-LBS is your magic number.
B B8200 Owner New member Apr 4, 2020 25 3 3 Kenosha, WI Jun 11, 2020 #3 N3BP said: Sequence attached....47.7-51.3 FT-LBS is your magic number. View attachment 44209 Click to expand... Thanks for the Information. The book I have said to start at 10, 14 to 1. I'm assuming That your sequence would be 1,6,4,2,5,3 9, 7 and so on.. Thanks
Henro Well-known member Equipment B2910, BX2200, KX41-2V mini Ex., Beer fridge May 24, 2019 5,803 2,994 113 North of Pittsburgh PA Jun 11, 2020 #4 B8200 Owner said: Thanks for the Information. The book I have said to start at 10, 14 to 1. I'm assuming That your sequence would be 1,6,4,2,5,3 9, 7 and so on.. Thanks Click to expand... Just wondering if they wanted the bolts tightened in the sequence you listed why they would not just number them that way in the diagram?
Pau7220 Well-known member Equipment L3650 GST, Landpride TL250 FEL w/ Piranha, 6' King Kutter, GM1084R Finish Aug 1, 2017 785 279 63 Scranton, PA Jun 11, 2020 #5 B8200 Owner said: Thanks for the Information. The book I have said to start at 10, 14 to 1. I'm assuming That your sequence would be 1,6,4,2,5,3 9, 7 and so on.. Thanks Click to expand... NO! Proper sequence is 1 to 14 in numerical order. Always start from the center and work outward. Heads, manifolds, or plywood... it's all the same.
