My comment is only addressed toward what is seen on a dipstick when first pulled for observation:
I have seen this on numerous occasions,... the need to pull the dipstick... WIPE IT CLEAN... then RE-INSERT it and obtain a fresh new reading. Oil can climb a dipstick due to capillary-action, and atmospheric pressure changes (barometer changes from day to day) can cause oil to climb or DESCEND a dipstick and give erroneous readings. (I have a reliable/repeatable example on my Yamaha F150 outboard, where if I simply pull the dipstick... it has NO OIL on it at all! Then, wiping and re-inserting it, the dipstick will read FULL. This is due (perhaps) to the engine cooling (contracting) after leaving the lake and SUCKING atmosphere into the sump via the dipstick tube thereby lowering the level of oil in that dipstick tube... making the dipstick read low/empty. But it will also occur days later after I’ve already checked it previously, so may have nothing to do with cooling.
Removing the dipstick (which has a very good seal at it’s base) allows atmosphere to equalize and oil in the sump to rise in the tube. REinserting the dipstick gives the proper reading. I also have an airplane that will indicate HIGH oil levels until I wipe the dipstick and reinsert it, in which case it will then correctly indicate oil level.)
Hope this helps.
