Greetings all,
I need a little direction here. The below email was my attempt to replace the attached picture item; Messick's confirmed that the part numbers shown within were the correct items and I ordered same. However, the plug is NOT vented and does NOT have the rubber tube extension. Did Kubota engineering make a design change or was I inadvertently mislead? If the vented plug and tube extension is appropriate, what would be the correct part number. Thank you for the assist, Montana Rick
Sent: Saturday, May 16, 2020 1:32 PM
To: Info Messicks <info@messicks.com>
Subject: Kubota Plug, hyd oil port plug, L2550DT4, crankcase (front)
Hello, I am trying to replace the attached picture item. Note that this has a breather vent hole and rubber extended tube?
Is your #38240-21410 & 04817-5030 an acceptable substitute or do I need a different part number selection?
Thank you and we appreciate your site and online videos, Rick
