Hello again,
The hits just keep coming! The charge light hasn't shut off in days, and my fuel gauge quit working. Went through all wires, fuses, grounds, etc and I can't seem to narrow the issue down.
Yesterday I checked both Dynamo wires and found each wire was putting 20v+ to the regulator while running, and dropped to 11-12v with key on, engine off. Battery hasn't shown more than 12.3v regardless.
I'm questioning if the regulator can partially fail and that's why the battery isn't getting a full charge? I say partially because it does put out 12v to the fuel gauge with the key on via the Red wire. Which leads me to my next issue. I think I fried the fuel gauge. It was stuck on full for about a week, then I realized it had no ground. Touched the wrong terminal, blew a fuse, replaced and properly wired it up, and now it doesn't work at all. Verified there was voltage via Y/B wire to sending unit as well. Wanna say it was around 6v+ (I might be mixing up the voltage between the R, and Y/B wires) I believe I have it wired in correctly. Pics below. Thank you!!!
