Hi, I have a L3901 HST. Done lots of field and compact tractor work, but never previously operated a HST. My apologies if this has been answered, but I made a reasonable effort to search the forums and couldn't find anything.
1. The PTO begins rotating PRIOR to me releasing the clutch. Is this okay? Do I actually NEED to utilize the clutch to engage the PTO? The manual indicates so, but strangely there's a warning both on the tractor and in the manual that says fully DISENGAGE the main clutch prior to switching the PTO on or damage may occur. I'm confused.
2. With previous tractors when running a brush hog, I simply throttled up all the way. The dealer said that wasn't the case or necessarily good, and that I should just get the tachometer to the PTO 540 mark. I'm not certain about this. Wouldn't any cutter work better with the engine running full throttle rather than just at the minimum 540 mark? By the way, I have a 6' Betstco Flail Mower now.
Thanks so much!
Justin
Thanks so much!
Justin
