Camp build
8upbowhunter
L4701 FEL, Cutter, Discs and Land Plane
Dec 15, 2016
402
72
S/E Louisiana
I am starting to build a camp on our property in S/W Mississippi and was wondering if anyone would be interested in following it. This will be a long term project taking about 2 years I am guessing. If there is enough interest I will start a new thread for the build.
3,467
Absolutely! Always looking to learn new techniques and see different ways different people approach problems.
5,097
Yeppers but remembering our camp,,,,, it is never finished, never :D
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
Maybe a brief outline of plan/scope of work?
We're doing something similar on our property in the SE Ohio Appalachian foothills.
8upbowhunter
Dec 15, 2016
402
72
S/E Louisiana
Plan is to build it from ground up doing all the work myself with help from a few others. 24x36 camp with 3 bedrooms, 1 bath and open kitchen/ living area. Will have a 8x36 porch across the front and a 20x20 deck on the back with a 10x16 across the rest of the back. After lots of debate my wife and I decided to go with Hardie planks on the outside and tongue and groove pine on the inside and a metal roof.
dalola
Jun 30, 2017
316
That sounds great, I would certainly follow along! Are you using std construction? Well & septic? Do you have contractor experience?
We are doing something similar, a bit smaller....24x24 on a walk-out, currently comparing timber frame, log, ICF, & conventional, and metal roof as well. If we do conventional, I like LP Smartside. Why do you prefer the Hardie?
I hope to start digging next spring.
8upbowhunter
Dec 15, 2016
402
72
S/E Louisiana
We are going standard construction, we have county water already ran back here and septic installed. Actually have a 14x28 1 bunk room camp with a 8x28 porch across the front we built 18 months ago for my brother inlaw but we all use it until this camp is finished.
To answer your question, I am not a carpenter, roofer, plumber or electrician by trade and never worked in those crafts. I have done lots of projects and helped friends and relatives on other projects and built the current camp so thats my experience level.
We chose hardie plank for no particular reason but that may change as I research more and the siding job gets closer.
8upbowhunter
Dec 15, 2016
402
72
S/E Louisiana
This is where we are in the process. All blocks are cemented in and filled with rebar and cement. I will start a new thread if I decide to do the build thread.
2,831
Hardie plank is harder to cut than other siding like the Smartside. The hardie plank is cement based and brittle to handle. It is 12 foot length so may have more joints. It does have the fire resistance advantage. It comes in many different appearances on the plank. I suggest you read their instructions carefully and install the trim first and siding second. There are many aftermarket things to help install lights, plugs and not have to deal with the slant of the planks.
If you don’t install a sheathing behind the hardie planks they will be wavy and also you can just run through the wall since the planks have little strength to impact.
I have it on my house and wish I had the smartside instead but not ready to replace it.
8upbowhunter
Dec 15, 2016
402
72
S/E Louisiana
Thanks for the heads up, I will do more research on both. I planned on putting sheathing all the way around it.
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
363
92
Canton, MS
8upbowhunter, what part of southwest ms are you in? I live in central ms.
shootem604
Apr 23, 2018
874
British Columbia
My brothers and I were looking at a piece of property with a small lake - planning to possibly drop a half dozen seacans that can be adapted for hunt camp cabins, wash up, and kitchen, and can be securely locked up.
8upbowhunter
Dec 15, 2016
402
72
S/E Louisiana
I’ve seen that done before [emoji1303].
old and tired
1,919
1,297
Count me in... I would just continue posting with this thread...
Do you have to deal with county inspections for the building?
8upbowhunter
Dec 15, 2016
402
72
S/E Louisiana
Thanks for the interest, there are no restrictions or inspections other than what I had to do to get the septic system installed before I could get power.
I will post some property info about what we started with and our plans going forward in the next week or so.
