Hi-
I was out working this weekend, doing some loader work and noticed, after parking the tractor that there was a very tiny bit of axle fluid around the front axle joint on the left side of my BX.
I just (like a month ago) had the seals replaced on both sides because the front left was leaking pretty steadily. To say this (some fluid around the knuckle) was aggravating would be an understatement.
I next removed the dipstick to check the level and to my surprise it shot out like a champagne cork! I've done a search on this and it does seem to be a common issue; that pressure builds in the front axle housing and in some cases, causes fluid to seep past the seals and/or shoots the dipstick out.
So couple of questions; I haven't noticed any dripping or leaks near the front left seal since I removed the dipstick and wiped away what little fluid was there.
-Do you think I now have another leak at the left front axle?
-Would it be worthwhile to try and put a breather of some type on the front axle to avoid the pressure build?
-If I do put a breather on, I was thinking of replacing one of the existing breather bolts with something with an actual breather...if I do this does anyone know what kind of bolts these are (metric, pitch, etc)?
Thanks for any help!
