So I'm slowly fixing up this L285. Noticed the water pump although not leaking was very loose. I went to searching for a replacement. I started with the parts manual I have and it shows 15401-73030(1,2,3 for last zero). Went to Merricks & Ebay and got confused. Merricks shows the 15401 number but Ebay shows it to be SN <3500. Then there is the 15321-73032 number which shows for a whole string of L numbers including the L285. The 285 & 345 has the 4 cylinder engine but the rest are 3 cylinder engines, same water pump?
Long story short the 15401 numbers start at $75 and go up, the 15321 start at $30 and up.
My L285 is SN 111**. Will the 15321 number fit?
Also trying to take the slop out of the front end, any clues?
